* configure.ac: Add AC_CONFIG_HEADER(config.h).
* sp01/init.c,
sp01/task1.c,
sp02/init.c,
sp02/preempt.c,
sp02/task1.c,
sp02/task2.c,
sp02/task3.c,
sp03/init.c,
sp03/task1.c,
sp03/task2.c,
sp04/init.c,
sp04/task1.c,
sp04/task2.c,
sp04/task3.c,
sp04/tswitch.c,
sp05/init.c,
sp05/task1.c,
sp05/task2.c,
sp05/task3.c,
sp06/init.c,
sp06/task1.c,
sp06/task2.c,
sp06/task3.c,
sp07/buffered_io.c,
sp07/init.c,
sp07/task1.c,
sp07/task2.c,
sp07/task3.c,
sp07/task4.c,
sp07/taskexit.c,
sp07/tcreate.c,
sp07/tdelete.c,
sp07/trestart.c,
sp07/tstart.c,
sp08/init.c,
sp08/task1.c,
sp09/delay.c,
sp09/init.c,
sp09/isr.c,
sp09/screen01.c,
sp09/screen02.c,
sp09/screen03.c,
sp09/screen04.c,
sp09/screen05.c,
sp09/screen06.c,
sp09/screen07.c,
sp09/screen08.c,
sp09/screen09.c,
sp09/screen10.c,
sp09/screen11.c,
sp09/screen12.c,
sp09/screen13.c,
sp09/screen14.c,
sp09/task1.c,
sp09/task2.c,
sp09/task3.c,
sp09/task4.c,
sp10/init.c,
sp11/init.c,
sp11/task1.c,
sp11/task2.c,
sp11/timer.c,
sp12/init.c,
sp12/pridrv.c,
sp12/pritask.c,
sp12/task1.c,
sp12/task2.c,
sp12/task3.c,
sp12/task4.c,
sp12/task5.c,
sp13/fillbuff.c,
sp13/init.c,
sp13/putbuff.c,
sp13/task1.c,
sp13/task2.c,
sp13/task3.c,
sp14/asr.c,
sp14/init.c,
sp14/task1.c,
sp14/task2.c,
sp15/init.c,
sp15/task1.c,
sp16/init.c,
sp16/task1.c,
sp16/task2.c,
sp16/task3.c,
sp16/task4.c,
sp16/task5.c,
sp17/asr.c,
sp17/init.c,
sp17/task1.c,
sp17/task2.c,
sp18/init.c,
sp19/first.c,
sp19/fptask.c,
sp19/init.c,
sp19/task1.c,
sp20/getall.c,
sp20/init.c,
sp20/task1.c,
sp21/init.c,
sp22/delay.c,
sp22/init.c,
sp22/prtime.c,
sp22/task1.c,
sp23/init.c,
sp23/task1.c,
sp24/init.c,
sp24/resume.c,
sp24/task1.c,
sp25/init.c,
sp25/task1.c,
sp26/init.c,
sp26/task1.c,
sp27/init.c,
sp28/init.c,
sp29/init.c,
sp30/init.c,
sp30/resume.c,
sp30/task1.c,
sp31/delay.c,
sp31/init.c,
sp31/prtime.c,
sp31/task1.c,
sp32/init.c,
sp33/init.c,
sp34/changepri.c,
sp35/priinv.c,
sp36/strict_order_mut.c,
sp37/init.c,
sp38/init.c,
sp39/init.c,
sp40/init.c,
sp41/init.c,
sp42/init.c,
sp43/init.c,
sp44/init.c,
sp45/init.c,
sp46/init.c,
sp47/init.c,
sp48/init.c,
sp49/init.c,
sp50/init.c,
sp51/init.c,
sp52/init.c,
sp54/init.c,
sp55/init.c,
sp56/init.c,
sp57/init.c,
sp58/init.c,
sp59/init.c,
sp60/init.c,
sp62/init.c,
sp63/init.c,
sp64/init.c,
sp65/init.c,
sp66/init.c,
sp67/init.c,
sp68/init.c,
sp69/init.c,
sp70/init.c,
sp71/init.c,
sp72/init.c,
spassoc01/init.c,
spchain/init.c,
spclockget/init.c,
spcoverage/init.c,
sperror01/init.c,
sperror02/init.c,
sperror03/init.c,
spfatal_support/consume_sems.c,
spfatal_support/init.c,
spfifo01/init.c,
spfifo02/init.c,
spfifo03/init.c,
spfifo04/init.c,
spfifo05/init.c,
spheapprot/init.c,
spintrcritical01/init.c,
spintrcritical06/init.c,
spintrcritical08/init.c,
spintrcritical09/init.c,
spintrcritical10/init.c,
spintrcritical11/init.c,
spintrcritical13/init.c,
spintrcritical15/init.c,
spintrcritical16/init.c,
spintrcritical17/init.c,
spintrcritical_support/intrcritical.c,
spmkdir/init.c,
spmountmgr01/init.c,
spnotepad01/init.c,
spobjgetnext/init.c,
spprintk/init.c,
spprivenv01/init.c,
spsize/getint.c,
spsize/init.c,
spsize/size.c,
spstkalloc/init.c,
spthreadq01/init.c,
spwatchdog/delay.c,
spwatchdog/init.c,
spwatchdog/prtime.c,
spwatchdog/task1.c,
spwkspace/init.c: Add HAVE_CONFIG_H.
* sp09/Makefile.am: Switch to all managers since this is all of them.
* sp69/init.c: Use "ld" instead of PRId32 to print
struct timespec->tv_nsec.
* sp19/inttest.h: Use PRIx32 instead of "lx".
* sp04/tswitch.c: Shrink memory requirements.
* spchain/init.c: Added test case.
* spchain/init.c, spchain/spchain.scn: More test cases.
PR 1647/cpukit
* spsize/size.c: Update documentation to reflect refactoring of
SuperCore to add Scheduler Handler.
* sp70/init.c, sp70/sp70.scn: Fix bug in test which lead to random
memory corruption.
* spchain/init.c: Attempt to improve coverage.
* spchain/init.c, spwatchdog/task1.c: Do not violate chain API.
* spfifo03/spfifo03.scn: Replace file.
* spsize/size.c: Fix typo.
PR 1663/testing
* spmkdir/init.c, spmkdir/spmkdir.scn: Added some test outputs to
the test.
* spheapprot/.cvsignore, spheapprot/Makefile.am,
spheapprot/spheapprot.doc, spheapprot/spheapprot.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spchain/init.c, spchain/spchain.doc, spchain/spchain.scn: New test
cases.
* spfatal24/.cvsignore, spfatal24/Makefile.am,
spfatal24/spfatal24.doc, spfatal24/spfatal24.scn,
spfatal24/testcase.h, spfatal25/.cvsignore, spfatal25/Makefile.am,
spfatal25/spfatal25.doc, spfatal25/spfatal25.scn,
spfatal25/testcase.h: New files.
PR 1658/cpukit
* Makefile.am, configure.ac: If the system is not up, consider it a
fatal error. This eliminated sp61 and added spfatal23.
* spfatal23/.cvsignore, spfatal23/Makefile.am, spfatal23/spfatal23.doc,
spfatal23/spfatal23.scn, spfatal23/testcase.h: New files.
* sp61/.cvsignore, sp61/Makefile.am, sp61/init.c, sp61/sp61.doc,
sp61/sp61.scn: Removed.
PR 1663/testing
* spmkdir/init.c: New cases to get the error path in rtems_mkdir
routine.
PR 1661/testing
* spfifo02/init.c, spmountmgr01/init.c, spprivenv01/init.c: Eliminate
most references to RTEMS_Malloc_Heap.
* sp09/screen12.c: Update for rtems_region_create() changes.
* sp09/sp09.scn: Update.
PR 1647/testing
* spsize/size.c: Remove redundant initialize uninitialized to 0.
PR 1599/cpukit
* spsize/size.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1621/testing
* Makefile.am, configure.ac: Improve coverage of private environment.
* spprivenv01/.cvsignore, spprivenv01/Makefile.am, spprivenv01/init.c,
spprivenv01/spprivenv01.doc, spprivenv01/spprivenv01.scn: New files.
* sp43/init.c, sp43/sp43.scn: Add code to exercise case where an API
pointer is NULL when getting an object name.
* sp11/sp11.scn, sp11/task1.c: Add test case for receiving all events
no wait but the condition is only partially satisfied.
* Makefile.am, configure.ac: Add test to extract a task blocked with
timeout on a priority ordered thread queue.
* sp72/.cvsignore, sp72/Makefile.am, sp72/init.c, sp72/sp72.doc,
sp72/sp72.scn: New files.
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/spmountmgr01.scn,
spmountmgr01/spmountmgr01.doc: Added cases to exercise
mount-mktgt.c.
PR 1617/testing
* spmountmgr01/init.c, spmountmgr01/Makefile.am,
spmountmgr/.cvsignore, spmountmgr01/spmountmgr01.doc,
spmountmgr01/spmountmgr01.scn: New test which improves coverage
of mount-mgr.c under libcsupport.
* Makefile.am, configure.ac: Changes to accommodate the new test.
* spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean
up and add test of getchark().
* spfatal21/Makefile.am: Fix typo.
* Makefile.am, configure.ac: Add tests for sbrk fatal error case and
libio initialization fatal error case.
* spfatal21/.cvsignore, spfatal21/Makefile.am, spfatal21/spfatal21.doc,
spfatal21/spfatal21.scn, spfatal21/testcase.h, spfatal22/.cvsignore,
spfatal22/Makefile.am, spfatal22/spfatal22.doc,
spfatal22/spfatal22.scn, spfatal22/testcase.h: New files.
* spintrcritical06/init.c: Switch semaphore obtain timeouts of
variants. Cleanup.
* spintrcritical05/spintrcritical05.scn,
spintrcritical06/spintrcritical06.scn,
spintrcritical07/spintrcritical07.scn,
spintrcritical11/spintrcritical11.scn,
spintrcritical12/spintrcritical12.scn,
spintrcritical13/spintrcritical13.scn,
spintrcritical14/spintrcritical14.scn: Update.
* Makefile.am, configure.ac: Readd spfatal09 as a malloc initialization
fatal error.
* spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc,
spfatal09/spfatal09.scn, spfatal09/testcase.h: New files.
PR 1603/testing
* spassoc01/init.c, spassoc01/Makefile.am,
spassoc01/spassoc01.doc, spassoc01/spassoc01.scn: Added new test.
* Makefile.am, configure.ac: Added new test spassoc01 for
rtems_assoc routines.
PR 1606/cpukit
* spfatal_support/init.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
spfatal09/spfatal09.doc, spfatal09/spfatal09.scn,
spfatal09/testcase.h: Removed files.
* spfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of
puts().
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal10/spfatal10.scn, spfatal11/spfatal11.scn,
spfatal12/spfatal12.scn, spfatal13/spfatal13.scn,
spfatal14/spfatal14.scn, spfatal15/spfatal15.scn,
spfatal16/spfatal16.scn, spfatal17/spfatal17.scn,
spfatal18/spfatal18.scn, spfatal19/spfatal19.scn,
spfatal20/spfatal20.scn: Update.
* sp21/init.c, sp21/sp21.scn: Tidy up with one last case to get 100%
coverage of rtems_io_lookup_name().
* sp21/Makefile.am, sp21/init.c, sp21/sp21.scn: Add
rtems_io_lookup_name() and simplify test.
* sp21/system.h, sp21/task1.c: Removed.
* Makefile.am, configure.ac: Add new fatal error test for termios
initialize.
* spfatal20/.cvsignore, spfatal20/Makefile.am, spfatal20/spfatal20.doc,
spfatal20/spfatal20.scn, spfatal20/testcase.h: New files.
PR 1600/testing
* spfifo05/init.c, spfifo05/spfifo05.doc, spfifo05/spfifo05.scn,
spfifo05/Makefile.am: New tests for pipe/fifo routines.
* Makefile.am, configure.ac: Add new test.
PR 1600/testing
* spfifo04/init.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn,
spfifo04/Makefile.am: New files to improve coverage on fifo/pipe
routines
* sp68/init.c: Add alignment to region_area. Fix spelling.
PR 1573/cpukit
* spsize/size.c: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* sp69/Makefile.am: Really needs spin.c
PR 1592/testing
* Makefile.am, configure.ac: Changes to incorporate sperror01,
sperror02, sperror03
* sperror01/init.c, sperror02/init.c: New tests to exercise
rtems_error routine
* sperror03/init.c: New test to exercise rtems_panic routine
* sp69/Makefile.am, sp71/Makefile.am, spfifo02/Makefile.am: Tests do
not need spin.c
* sp70/Makefile.am: Tests do not need spin.c
