path: root/testsuites/smptests (follow)
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1139-108/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0711-0/+51
* Remove CVS-Ids.Ralf Corsépius2012-05-0411-51/+0
* Remove.Ralf Corsépius2012-05-041-0/+0
* smp08 screen replacementJoel Sherrill2012-04-241-16/+29
* Remove all .cvsignore files.Joel Sherrill2012-02-0110-33/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-0810-22/+17
| | | | | | | | PR 1589/build * smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am, smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am, smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove obsolete optional manager capability.
* 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-295-0/+21
| | | | | * smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c: Add HAVE_CONFIG_H.
* 2011-07-29 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett2011-07-294-16/+38
| | | | | | | | * smp03/init.c, smp03/system.h, smp03/tasks.c: Modified test to force a task to run prior to starting the next task. This allows the last task to always preempt, where if the tasks started in an odd order the last task could run prior the the task it was supposed to preempt.
* 2011-07-29 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett2011-07-2913-70/+75
| | | | | | | | * smp01/init.c, smp02/init.c, smp02/tasks.c, smp03/init.c, smp03/tasks.c, smp04/Makefile.am, smp04/init.c, smp05/init.c, smp06/init.c, smp07/init.c, smp08/init.c: Cleaned up tests and fixed some print statement problems. * smp04/tasks.c: Removed.
* 2011-06-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-2910-24/+17
| | | | | | * smp01/smp01.doc, smp02/smp02.doc, smp03/smp03.doc, smp04/smp04.doc, smp05/smp05.doc, smp07/smp07.doc, smp08/smp08.doc, smp08/system.h, smp08/tasks.c: Update copyright.
* 2011-06-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-292-0/+19
| | | | * .cvsignore: New file.
* 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-2861-0/+2186
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in, configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c, smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c, smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc, smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore, smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn, smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am, smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h, smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c, smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore, smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn, smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc, smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c, smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c, smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc, smp09/smp09.scn: New files.
