Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
test suites using the RTEMS Test Framework.
Close #4034.
Normally, the expected test step must be a compile time constant. Allow
variable expected test steps for the T_step() and T_assert_step(). This
can be used for parameterized test loops with individual fixtures.
Remove the ability to use custom failure messages due to some
implementation constraints.
Update #3199.
Update #3199.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
The signal handler of the consumer might start executing
before rtems_signal_send of the producer returns.
Therefore change the state to SIG_1_SENT before sending the signal.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3838.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Problem introduced by 77ac1519e863b7095f69c976353f7647c6f6f63b.
Use CONFIGURE_MAXIMUM_PROCESSORS to configure the EDF SMP scheduler
context. This avoids hard to debug configuration errors resulting in
memory corruptions.
Close #3815.
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Use separator character '_' for all test states.
Update #3818.
Process only the jobs initially registered on the processing list. This
makes it possible to add jobs for the current processor in a job
handler. These jobs are processed with the next
SMP_MESSAGE_PERFORM_JOBS message. The lock is only acquired and
released once.
Move resposibility to disable thread dispatching to the caller of
_SMP_Multicast_action(). Using an interrupt disable for this purpose is
questionable.
If the caller already disabled interrupts, then do not disable thread
dispatching. Calling _SMP_Multicast_action() with interrupts disabled
is a questionable use case.
Let it work during system initialization.
Use a FIFO list of jobs per processor to carry out the SMP multicast
action. Use a done indicator per job to reduce the bus traffic a bit.
Processor_mask is the internal data type to deal with processor sets.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
We must add/remove the priority queue to the FIFO of priority queues.
Update #3000.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
The following rtems_cache_*_processor_set() cache manager API functions
are exotic, complex, very hard to use correctly, not used in the RTEMS
code base, and apparently unused by applications.
Close #3622.
Update #2514.
Update #3533.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
Fix a special case: block a one-to-one scheduled thread while having a
non-empty affine ready queue on the same processor.
Pass current processor control as first parameter in
bsp_start_on_secondary_processor() and qoriq_start_thread() to make
dependency more explicit.
