Update #3433.
Update #3409.
upgrade to that version.
Close #3387.
Update #3382
Update #3325.
The rtems_test_busy() is not accurate enough and may lead to sporadic
test failures.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #2843.
This test uses sprintf().
Update test documentation to include more cases.
Updates #3000.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
We must not clear the priority updates in _Thread_queue_Extract_locked()
since this function is used by the priority ceiling surrender operations
after the ceiling priority handover from the previous owner to the new
owner. This is especially important in SMP configurations.
Move the _Thread_queue_Context_clear_priority_updates() invocation to
the callers.
Close #3237.
The thread queue extract operations performed by the
_Thread_queue_Flush_critical() may result in a priority change of the
thread queue owner. Carry out the scheduler priority update operation.
Close #3236.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
The pthread_getattr_np() returns now the stack address and size. Do not
use this stack for the new threads.
Update #2514.
Update #3145.
Update #3168.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Close #3187.
Updates #3170.
call to printk.
Updates #3170.
Update #2514.
Update #2514.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Update #2132.
Update #3082.
Update #3059.
Update #3063.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Update #3076.
Update #3070.
Update #3069.
Ensure that the thread processor affinity fits the new scheduler
instance.
Update #3059.
Update #3059.
Update #3059.
