* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 39 | -108/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 11 | -0/+51 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 11 | -51/+0 |
* | Remove. | Ralf Corsépius | 2012-05-04 | 1 | -0/+0 |
* | smp08 screen replacement | Joel Sherrill | 2012-04-24 | 1 | -16/+29 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 10 | -33/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 10 | -22/+17 |
| | | | | | | | | PR 1589/build * smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am, smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am, smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-09-29 | 5 | -0/+21 |
| | | | | | * smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c: Add HAVE_CONFIG_H. | ||||
* | 2011-07-29 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-07-29 | 4 | -16/+38 |
| | | | | | | | | * smp03/init.c, smp03/system.h, smp03/tasks.c: Modified test to force a task to run prior to starting the next task. This allows the last task to always preempt, where if the tasks started in an odd order the last task could run prior the the task it was supposed to preempt. | ||||
* | 2011-07-29 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-07-29 | 13 | -70/+75 |
| | | | | | | | | * smp01/init.c, smp02/init.c, smp02/tasks.c, smp03/init.c, smp03/tasks.c, smp04/Makefile.am, smp04/init.c, smp05/init.c, smp06/init.c, smp07/init.c, smp08/init.c: Cleaned up tests and fixed some print statement problems. * smp04/tasks.c: Removed. | ||||
* | 2011-06-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-29 | 10 | -24/+17 |
| | | | | | | * smp01/smp01.doc, smp02/smp02.doc, smp03/smp03.doc, smp04/smp04.doc, smp05/smp05.doc, smp07/smp07.doc, smp08/smp08.doc, smp08/system.h, smp08/tasks.c: Update copyright. | ||||
* | 2011-06-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-29 | 2 | -0/+19 |
| | | | | * .cvsignore: New file. | ||||
* | 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-28 | 61 | -0/+2186 |
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in, configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c, smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c, smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc, smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore, smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn, smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am, smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h, smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c, smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore, smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn, smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc, smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c, smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c, smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc, smp09/smp09.scn: New files. |
