Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Update #2811.
Per task variables are inherently unsafe in SMP systems. This
patch disables them from the build and adds warnings in the
appropriate documentation and configuration sections.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
The thread restart is now supported on SMP. New test
smptests/smpthreadlife01.
A common use case for disabled preemption was to ensure mutual exclusion
on single-processor configurations. On SMP this does not work.
To abandon non-preemptible tasks simplifies the scheduler.
Task variables are not supported on SMP.
Task deletion is currently not implemented on SMP configurations.
Add a configuration field which indicates if the SMP mode of operation
is enabled. This can be used to disable features unsupported on SMP,
e.g task variables.
