brains GmbH.
Updates #3053.
Updates #4625.
Update smpstrongapa01 to account for task shifting.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3732.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3059.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
This helps to prevent stack overflows due to configuration errors.
