2020-07-23 | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 1 | -1/+1 | |
Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | |||||
2018-04-10 | testsuite/smptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 1 | -19/+0 | |
This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2018-03-12 | config: Use new scheduler configuration defines | Sebastian Huber | 1 | -4/+4 | |
Update #3325. | |||||
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-06-29 | smptests: Split smpscheduler03 | Sebastian Huber | 4 | -0/+91 | |
Split smpscheduler03 to run the tests with only one processor. Update #3056. |
