Update #3732.
Fix a special case: block a one-to-one scheduled thread while having a
non-empty affine ready queue on the same processor.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3059.
