Use CONFIGURE_MAXIMUM_PROCESSORS to configure the EDF SMP scheduler
context. This avoids hard to debug configuration errors resulting in
memory corruptions.
Close #3815.
Update #3325.
The rtems_test_busy() is not accurate enough and may lead to sporadic
test failures.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Update #3059.
Update #3056.
