* | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -1/+1 |
| | | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894. | ||||
* | Remove CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-02 | 1 | -2/+0 |
| | | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893. | ||||
* | smpschedaffinity02: Remove unused prototype. | Jennifer Averett | 2014-11-25 | 1 | -1/+0 |
* | smpschedaffinity02: Change semaphore attributes. | Jennifer Averett | 2014-11-20 | 1 | -5/+4 |
| | | | | | Change semaphore attributes to prevent semaphore from being locked and never released upon a context switch. | ||||
* | smpschedaffinity02: New test. | Jennifer Averett | 2014-07-11 | 4 | -0/+281 |
This test checks setting the affinity of a secondary task on a two core system. |
