Update #3170.
Update #3199.
The pthread_getattr_np() returns now the stack address and size. Do not
use this stack for the new threads.
Update #2514.
Update #3145.
Update #3168.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #2514.
Update #3059.
Update #3059.
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
This method exercises the ability to dynamically get and set
the affinity of POSIX threads.
NOTE: There is no scheduler support for affinity. This is
simply a data integrity test.
