2014-06-13 | smptests: Avoid use of uninitialized data | Sebastian Huber | 1 | -0/+2 | |
2014-04-11 | rtems: Rename rtems_smp_get_processor_count() | Sebastian Huber | 1 | -1/+1 | |
Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations. | |||||
2014-04-03 | smppsxaffinity02: Use Priority Affinity SMP scheduler. | Jennifer Averett | 1 | -0/+1 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 2 | -2/+2 | |
2014-03-17 | tests/smptests: Use <rtems/test.h> | Sebastian Huber | 1 | -4/+6 | |
2014-03-10 | smptests/smppsxaffinity02: Fix end of test message | Sebastian Huber | 1 | -1/+1 | |
2014-03-07 | Remove trailing whitespace in previous patches | Jennifer Averett | 2 | -18/+18 | |
2014-03-07 | smptests: Add smppsxaffinity02. | Jennifer Averett | 4 | -0/+302 | |
This method exercises the ability to dynamically get and set the affinity of POSIX threads. NOTE: There is no scheduler support for affinity. This is simply a data integrity test. |
