* | powerpc: Add _CPU_Get_current_per_CPU_control() | Sebastian Huber | 2016-11-10 | 1 | -460/+460 |
| | | | | | | | | Add _CPU_Get_current_per_CPU_control() on SMP configurations. Use SPRG0 for the current per-CPU control. This reduces the code size by three instructions and is slightly faster. Update #2805. | ||||
* | score: Inline some SMP lock operations by default | Sebastian Huber | 2016-11-09 | 1 | -468/+468 |
| | | | | | | | | | The SMP ticket lock release turned out to be suitable for inlining, e.g. a hand full of instructions, no branches. The changes in the screen files do not reflect the changes due to this commit. However, they are now up to date. Obtained on a T4240 running at 1.5GHz using GCC 7.0.0 20161108.. | ||||
* | smptests/smpmutex02: New test | Sebastian Huber | 2016-07-25 | 1 | -0/+578 |
Update #2765. |
