Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
We must add/remove the priority queue to the FIFO of priority queues.
Update #3382
Update #3325.
We must not clear the priority updates in _Thread_queue_Extract_locked()
since this function is used by the priority ceiling surrender operations
after the ceiling priority handover from the previous owner to the new
owner. This is especially important in SMP configurations.
Move the _Thread_queue_Context_clear_priority_updates() invocation to
the callers.
Close #3237.
The thread queue extract operations performed by the
_Thread_queue_Flush_critical() may result in a priority change of the
thread queue owner. Carry out the scheduler priority update operation.
Close #3236.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Update #2556.
Update #2556.
Maintain the priority of a thread for each scheduler instance via the
thread queue enqueue, extract, priority actions and surrender
operations. This replaces the primitive priority boosting.
Update #2556.
Update #2556.
Update #2784.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Task priorities are only valid within a scheduler instance. The
rtems_task_set_scheduler() directive moves a task from one scheduler
instance to another using the current priority of the thread. However,
the current task priority of the source scheduler instance is undefined
in the target scheduler instance. Add a third parameter to specify the
priority.
Close #2749.
This define accidentally re-appeared.
