The order in which step checks for 1 and 2 are not rigidly defined and
may actually occur in either order depending on how the threads execute.
This waits for the job to complete to enforce the existing ordering.
Use the processor control to specify the target processor since this is what
the callers have available.
Remove _CPU_SMP_Processor_event_broadcast() and
_CPU_SMP_Processor_event_receive(). These functions are hard to use since they
are subject to the lost wake up problem.
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
test suites using the RTEMS Test Framework.
Normally, the expected test step must be a compile time constant. Allow
variable expected test steps for the T_step() and T_assert_step(). This
can be used for parameterized test loops with individual fixtures.
Remove the ability to use custom failure messages due to some
implementation constraints.
Update #3199.
Update #3199.
Problem introduced by 77ac1519e863b7095f69c976353f7647c6f6f63b.
Process only the jobs initially registered on the processing list. This
makes it possible to add jobs for the current processor in a job
handler. These jobs are processed with the next
SMP_MESSAGE_PERFORM_JOBS message. The lock is only acquired and
released once.
Move resposibility to disable thread dispatching to the caller of
_SMP_Multicast_action(). Using an interrupt disable for this purpose is
questionable.
If the caller already disabled interrupts, then do not disable thread
dispatching. Calling _SMP_Multicast_action() with interrupts disabled
is a questionable use case.
Let it work during system initialization.
Use a FIFO list of jobs per processor to carry out the SMP multicast
action. Use a done indicator per job to reduce the bus traffic a bit.
Processor_mask is the internal data type to deal with processor sets.
