Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3382
Update #3325.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Update #2556.
Update #2556.
Task priorities are only valid within a scheduler instance. The
rtems_task_set_scheduler() directive moves a task from one scheduler
instance to another using the current priority of the thread. However,
the current task priority of the source scheduler instance is undefined
in the target scheduler instance. Add a third parameter to specify the
priority.
Close #2749.
A 32-bit Priority_Control limits the uptime to 49 days with a 1ms clock
tick in case the EDF scheduler is used. Increase it to 64-bit to enable
proper operation of the EDF scheduler,
Close 2173.
Commit 77ff5599e0d8e6d91190a379be21a332f83252b0 introduced a change in
the rtems_semaphore_create() behaviour for MrsP semaphores. The ceiling
priorities for all schedulers except the scheduler of the executing
thread are initialized to zero.
Account for priority changes of threads executing in a foreign
partition. Exchange idle threads in case a victim node uses an idle
thread and the new scheduled node needs an idle thread.
Do not supsend self while waiting for termination since the
rtems_task_delete() may take place while the rtems_task_suspend() waits
for the Giant lock preventing delivery of the inter-processor interrupt.
The result is a suspended and terminated thread (this is a valid state,
but leads in this case to a test failure).
On the Freescale T2080 the excessive concurrent write/read lead to a
livelock condition.
The previous timeout handling was flawed. In case a waiting thread
helped out the owner could use the scheduler node indefinitely long.
Update the resource tree in _MRSP_Timeout() to avoid this issue.
Bug reported by Luca Bonato.
Use busy waits instead of sleeps to avoid unnecessary switches to the
idle thread.
Ensure that scheduler nodes in the SCHEDULER_HELP_ACTIVE_OWNER or
SCHEDULER_HELP_ACTIVE_RIVAL helping state are always
SCHEDULER_SMP_NODE_READY or SCHEDULER_SMP_NODE_SCHEDULED to ensure the
MrsP protocol properties.
New test case for smptests/smpmrsp01.
Fix _Scheduler_Block_node() in case the node is in the
SCHEDULER_HELP_ACTIVE_RIVAL helping state. For example a
rtems_task_suspend() on a task waiting for a MrsP semaphore.
Fix _Scheduler_Unblock_node() in case the node is in the
SCHEDULER_SMP_NODE_READY state. For example a rtems_task_resume() on a
task owning or waiting for a MrsP semaphore.
Do not extract the idle threads from the ready set so that there is
always a thread available for comparison.
This enables proper resource dependency tracking and as a side-effect
deadlock detection.
Add basic support for the Multiprocessor Resource Sharing Protocol
(MrsP).
The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
generalization of the Priority Ceiling Protocol to SMP systems. Each
MrsP semaphore uses a ceiling priority per scheduler instance. These
ceiling priorities can be specified with rtems_semaphore_set_priority().
A task obtaining or owning a MrsP semaphore will execute with the
ceiling priority for its scheduler instance as specified by the MrsP
semaphore object. Tasks waiting to get ownership of a MrsP semaphore
will not relinquish the processor voluntarily. In case the owner of a
MrsP semaphore gets preempted it can ask all tasks waiting for this
semaphore to help out and temporarily borrow the right to execute on one
of their assigned processors.
The help out feature is not implemented with this patch.
