Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
