path: root/testsuites/smptests/smpipi01 (follow)
* smptests/smpipi01: Fix sporadic test failureSebastian Huber2020-12-091-0/+7
* score: Add _SMP_Synchronize()Sebastian Huber2019-05-201-3/+4
* smpipi01: Use per-CPU jobs for IPI flood testSebastian Huber2019-05-201-9/+38
* smpipi01: Ensure IPI works on all processorsSebastian Huber2019-05-201-8/+21
* smpipi01: Use per-CPU jobs for pending IPI testSebastian Huber2019-05-201-15/+35
* rtems: Add rtems_scheduler_get_processor_maximum()Sebastian Huber2019-04-091-2/+2
| | | | | | | | | | | Add rtems_scheduler_get_processor_maximum() as a replacement for rtems_get_processor_count(). The rtems_get_processor_count() is a bit orphaned. Adopt it by the Scheduler Manager. The count is also misleading, since the processor set may have gaps and the actual count of online processors may be less than the value returned by rtems_get_processor_count(). Update #3732.
* rtems: Add rtems_scheduler_get_processor()Sebastian Huber2019-04-091-2/+2
| | | | | | | | | | | Add rtems_scheduler_get_processor() as a replacement for rtems_get_current_processor(). The rtems_get_current_processor() is a bit orphaned. Adopt it by the Scheduler Manager. This is in line with the glibc sched_getcpu() function. Deprecate rtems_get_current_processor(). Update #3731.
* testsuite/smptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-19/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: Introduce _SMP_Get_online_processors()Sebastian Huber2017-07-071-2/+2
| | | | Update #3059.
* score: Use <sys/bitset.h> for Processor_maskSebastian Huber2017-07-061-2/+2
| | | | | | | | Implement the Processor_mask via <sys/bitset.h>. Provide _Processor_mask_To_uint32_t() to enable its use in device specific routines, e.g. interrupt affinity register in an interrupt controller. Update #3059.
* Rename CONFIGURE_SMP_MAXIMUM_PROCESSORSSebastian Huber2017-02-141-1/+1
| | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894.
* Remove CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-021-2/+0
| | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893.
* score: Add _SMP_Online_processorsSebastian Huber2016-03-041-0/+10
* tests: Add documentationSebastian Huber2014-09-011-1/+3
* score: Add SMP test message handlerSebastian Huber2014-05-054-0/+243
This handler can be used to test the inter-processor interrupt implementation.
