* | score: Fix per-CPU data allocation | Sebastian Huber | 2018-12-18 | 3 | -0/+105 |
Allocate the per-CPU data for secondary processors directly from the heap areas before heap initialization and not via _Workspace_Allocate_aligned(). This avoids dependency on the workspace allocator. It fixes also a problem on some platforms (e.g. QorIQ) where at this early point in the system initialization the top of the RAM is used by low-level startup code on secondary processors (boot pages). Update #3507. |
