path: root/testsuites/smptests/smpfatal09 (unfollow)
2020-02-14smpfatal09: Fix test caseSebastian Huber1-6/+0
Update #3838.
2020-02-04bsps: Rework work area initializationSebastian Huber1-4/+29
The work area initialization was done by the BSP through bsp_work_area_initialize(). This approach predated the system initialization through the system initialization linker set. The workspace and C program heap were unconditionally initialized. The aim is to support RTEMS application configurations which do not need the workspace and C program heap. In these configurations, the workspace and C prgram heap should not get initialized. Change all bsp_work_area_initialize() to implement _Memory_Get() instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and malloc() heap initialization into separate system initialization steps. This makes it also easier to test the individual initialization steps. This change adds a dependency to _Heap_Extend() to all BSPs. This dependency will be removed in a follow up change. Update #3838.
2019-12-05libtest: Change expected pass state stringSebastian Huber1-1/+1
Use separator character '_' for all test states.
2018-12-18score: Fix per-CPU data allocationSebastian Huber3-0/+105
Allocate the per-CPU data for secondary processors directly from the heap areas before heap initialization and not via _Workspace_Allocate_aligned(). This avoids dependency on the workspace allocator. It fixes also a problem on some platforms (e.g. QorIQ) where at this early point in the system initialization the top of the RAM is used by low-level startup code on secondary processors (boot pages). Update #3507.
