path: root/testsuites/smptests/smpfatal06 (follow)
* score: Robust thread dispatchSebastian Huber2016-11-234-0/+103
| | | | | | | | | | | | On SMP configurations, it is a fatal error to call blocking operating system with interrupts disabled, since this prevents delivery of inter-processor interrupts. This could lead to executing threads which are not allowed to execute resulting in undefined behaviour. The ARM Cortex-M port has a similar problem, since the interrupt state is not a part of the thread context. Update #2811.
* score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORSSebastian Huber2014-05-054-113/+0
| | | | | Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
* score: Add clustered/partitioned schedulingSebastian Huber2014-04-154-0/+113
Clustered/partitioned scheduling helps to control the worst-case latencies in the system. The goal is to reduce the amount of shared state in the system and thus prevention of lock contention. Modern multi-processor systems tend to have several layers of data and instruction caches. With clustered/partitioned scheduling it is possible to honour the cache topology of a system and thus avoid expensive cache synchronization traffic. We have clustered scheduling in case the set of processors of a system is partitioned into non-empty pairwise-disjoint subsets. These subsets are called clusters. Clusters with a cardinality of one are partitions. Each cluster is owned by exactly one scheduler instance.
