path: root/testsuites/smptests/smpfatal01 (follow)
* testsuite/smptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-19/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* tests: Remove obsolete TESTS_USE_PRINTKSebastian Huber2017-10-281-1/+0
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Rename CONFIGURE_SMP_MAXIMUM_PROCESSORSSebastian Huber2017-02-141-1/+1
| | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894.
* Remove CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-021-2/+0
| | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893.
* Rename is_internal to always_set_to_falseSebastian Huber2016-12-121-2/+2
| | | | Update #2825.
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-4/+6
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* tests/smptests: Normal use of test extensionSebastian Huber2014-10-241-2/+2
* tests/smptests: Use barriers in smpfatal0{12}Sebastian Huber2014-10-231-2/+9
| | | | | Call the test extension explicitly and wait for report output using a barrier. This avoids problems with an early shutdown of the system.
* rtems: Rename rtems_smp_get_current_processor()Sebastian Huber2014-04-111-2/+2
| | | | | | | Rename rtems_smp_get_current_processor() in rtems_get_current_processor(). Make rtems_get_current_processor() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* rtems: Rename rtems_smp_get_processor_count()Sebastian Huber2014-04-111-1/+1
| | | | | | Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* tests/smptests: Use <rtems/test.h>Sebastian Huber2014-03-171-9/+9
* score: SMP initialization and shutdown changesSebastian Huber2014-03-064-0/+163
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into _SMP_Request_start_multitasking() since this requests now a multitasking start on all configured and available processors. The name corresponds _Thread_Start_multitasking() and _SMP_Start_multitasking_on_secondary_processor() actions issued in response to this request. Move in source file to right place. Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into PER_CPU_STATE_READY_TO_START_MULTITASKING. Rename PER_CPU_STATE_BEGIN_MULTITASKING into PER_CPU_STATE_REQUEST_START_MULTITASKING. Rename _SMP_Request_other_cores_to_shutdown() into _SMP_Request_shutdown(). Add a per-CPU state lock to protect all changes. This was necessary to offer a controlled shutdown of the system (atomic read/writes alone are not sufficient for this kind of synchronization). Add documentation for Per_CPU_State. Delete debug output. New tests smptests/smpfatal01 and smptests/smpfatal02.
