Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Demonstrate that a read-modify-write atomic operation may be necessary
on some archtitectures to observe the latest value written.
Do not obfuscate the standard API.
Add rtems_test_parallel_get_task_id().
Make <rtems/score/atomic.h> available for all RTEMS configurations. Use
inline functions instead of macros. Use ISR disable/enable on
uni-processor configurations to ensure atomicity.
Update #2273.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Use unsigned long instead of uint_fast32_t since C11 provides only a
ATOMIC_LONG_LOCK_FREE macro constant. This makes it also possible to
use properly typed integer literals like 123UL. It is now clear which
compatible type should be used for the atomic integer.
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
