path: root/testsuites/smptests/smp09 (follow)
* smp09: Resolve missing prototype warning.Jennifer Averett2014-11-251-0/+8
* rtems: Rename rtems_smp_get_current_processor()Sebastian Huber2014-04-111-1/+1
| | | | | | | Rename rtems_smp_get_current_processor() in rtems_get_current_processor(). Make rtems_get_current_processor() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* rtems: Rename rtems_smp_get_processor_count()Sebastian Huber2014-04-111-1/+1
| | | | | | Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* tests/smptests: Use <rtems/test.h>Sebastian Huber2014-03-171-2/+7
* smp: Add and use _CPU_SMP_Get_current_processor()Sebastian Huber2013-07-171-4/+4
| | | | | | | | | | Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type.
* score: Rename rtems_smp_get_number_of_processors()Sebastian Huber2013-06-141-1/+1
| | | | | | | | | Rename in rtems_smp_get_processor_count(). Always provide <rtems/score/smp.h> and <rtems/rtems/smp.h>. Add _SMP_Get_processor_count(). This function will be a compile time constant defined to be one on uni-processor configurations. This allows iterations over all processors without overhead on uni-processor configurations.
* smptests/smp09: Add missing newlineSebastian Huber2013-05-271-1/+1
* smptests/smp01: Fix semaphore countSebastian Huber2013-05-271-0/+2
| | | | The locked print needs one semaphore.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-2/+1
| | | | | | | | PR 1589/build * smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am, smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am, smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove obsolete optional manager capability.
* 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-291-0/+4
| | | | | * smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c: Add HAVE_CONFIG_H.
* 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-285-0/+161
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in, configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c, smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c, smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc, smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore, smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn, smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am, smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h, smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c, smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore, smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn, smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc, smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c, smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c, smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc, smp09/smp09.scn: New files.
