* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -2/+2 |
| | | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894. | ||||
* | Remove CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-02 | 1 | -1/+0 |
| | | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893. | ||||
* | smp09: Resolve missing prototype warning. | Jennifer Averett | 2014-11-25 | 1 | -0/+8 |
* | rtems: Rename rtems_smp_get_current_processor() | Sebastian Huber | 2014-04-11 | 1 | -1/+1 |
| | | | | | | | Rename rtems_smp_get_current_processor() in rtems_get_current_processor(). Make rtems_get_current_processor() a function in uni-processor configurations to enable ABI compatibility with SMP configurations. | ||||
* | rtems: Rename rtems_smp_get_processor_count() | Sebastian Huber | 2014-04-11 | 1 | -1/+1 |
| | | | | | | Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/smptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -2/+7 |
* | smp: Add and use _CPU_SMP_Get_current_processor() | Sebastian Huber | 2013-07-17 | 1 | -4/+4 |
| | | | | | | | | | | Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type. | ||||
* | score: Rename rtems_smp_get_number_of_processors() | Sebastian Huber | 2013-06-14 | 1 | -1/+1 |
| | | | | | | | | | Rename in rtems_smp_get_processor_count(). Always provide <rtems/score/smp.h> and <rtems/rtems/smp.h>. Add _SMP_Get_processor_count(). This function will be a compile time constant defined to be one on uni-processor configurations. This allows iterations over all processors without overhead on uni-processor configurations. | ||||
* | smptests/smp09: Add missing newline | Sebastian Huber | 2013-05-27 | 1 | -1/+1 |
* | smptests/smp01: Fix semaphore count | Sebastian Huber | 2013-05-27 | 1 | -0/+2 |
| | | | | The locked print needs one semaphore. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | PR 1589/build * smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am, smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am, smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-09-29 | 1 | -0/+4 |
| | | | | | * smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c: Add HAVE_CONFIG_H. | ||||
* | 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-28 | 5 | -0/+161 |
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in, configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c, smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c, smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc, smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore, smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn, smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am, smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h, smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c, smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore, smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn, smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc, smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c, smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c, smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc, smp09/smp09.scn: New files. |
