Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
Update #3533.
Update #3382
This test uses sprintf().
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Rename rtems_smp_get_current_processor() in
rtems_get_current_processor(). Make rtems_get_current_processor() a
function in uni-processor configurations to enable ABI compatibility
with SMP configurations.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Task deletion is currently not implemented on SMP configurations.
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
In case the printf() blocks on a semaphore it was possible to end up in
a livelock.
The locked print needs one semaphore.
for details.
PR 1589/build
* smp01/Makefile.am, smp02/Makefile.am, smp03/Makefile.am,
smp04/Makefile.am, smp05/Makefile.am, smp06/Makefile.am,
smp07/Makefile.am, smp08/Makefile.am, smp09/Makefile.am: Remove
obsolete optional manager capability.
* smp01/init.c, smp02/init.c, smp02/tasks.c, smp03/init.c,
smp03/tasks.c, smp04/Makefile.am, smp04/init.c, smp05/init.c,
smp06/init.c, smp07/init.c, smp08/init.c: Cleaned up tests and fixed
some print statement problems.
* smp04/tasks.c: Removed.
* smp01/smp01.doc, smp02/smp02.doc, smp03/smp03.doc, smp04/smp04.doc,
smp05/smp05.doc, smp07/smp07.doc, smp08/smp08.doc, smp08/system.h,
smp08/tasks.c: Update copyright.
* .configure.ac.swp, ChangeLog, Makefile.am, README, config.h.in,
configure.ac, smp01/.cvsignore, smp01/Makefile.am, smp01/init.c,
smp01/smp01.doc, smp01/smp01.scn, smp01/system.h, smp01/tasks.c,
smp02/.cvsignore, smp02/Makefile.am, smp02/init.c, smp02/smp02.doc,
smp02/smp02.scn, smp02/system.h, smp02/tasks.c, smp03/.cvsignore,
smp03/Makefile.am, smp03/init.c, smp03/smp03.doc, smp03/smp03.scn,
smp03/system.h, smp03/tasks.c, smp04/.cvsignore, smp04/Makefile.am,
smp04/init.c, smp04/smp04.doc, smp04/smp04.scn, smp04/system.h,
smp04/tasks.c, smp05/.cvsignore, smp05/Makefile.am, smp05/init.c,
smp05/smp05.doc, smp05/smp05.scn, smp06/.cvsignore,
smp06/Makefile.am, smp06/init.c, smp06/smp06.doc, smp06/smp06.scn,
smp07/.cvsignore, smp07/Makefile.am, smp07/init.c, smp07/smp07.doc,
smp07/smp07.scn, smp08/.cvsignore, smp08/Makefile.am, smp08/init.c,
smp08/smp08.doc, smp08/smp08.scn, smp08/system.h, smp08/tasks.c,
smp09/.cvsignore, smp09/Makefile.am, smp09/init.c, smp09/smp09.doc,
smp09/smp09.scn: New files.
