Close #3250.
Close #4081.
Processor_mask is the internal data type to deal with processor sets.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
Commit 8744498752ad4f0eaf9fb5640c6a0e0f2dc92fda broke the
_Scheduler_EDF_SMP_Set_affinity() implementation. We must test the
overall affinity against the online processors.
Update #3409.
upgrade to that version.
Close #3387.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3059.
Update #3056.
Update #3056.
Split smpscheduler03 to run the tests with only one processor.
Update #3056.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
Update #2797.
Update #2556.
Update #2765.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Update #2555.
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Invokes SMP cache management routines under different scenarios.
This test verifies priority is inherited from a high priority
semaphore by a lower priority task.
This test uses a combination of priority and affinity to cause
the tasks running on all 4 cores to change due to one task priority
change.
This test walks a secondary high prority task across
all the cores.
This task walks the affinity of self across all the cores.
This test checks setting the affinity of a secondary task
on a two core system.
This test verifies that affinity is honored when set prior to task start.
Add basic support for the Multiprocessor Resource Sharing Protocol
(MrsP).
The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
generalization of the Priority Ceiling Protocol to SMP systems. Each
MrsP semaphore uses a ceiling priority per scheduler instance. These
ceiling priorities can be specified with rtems_semaphore_set_priority().
A task obtaining or owning a MrsP semaphore will execute with the
ceiling priority for its scheduler instance as specified by the MrsP
semaphore object. Tasks waiting to get ownership of a MrsP semaphore
will not relinquish the processor voluntarily. In case the owner of a
MrsP semaphore gets preempted it can ask all tasks waiting for this
semaphore to help out and temporarily borrow the right to execute on one
of their assigned processors.
The help out feature is not implemented with this patch.
Do not use the Per_CPU_Control::started in
_SMP_Start_multitasking_on_secondary_processor() since this field may be
not up to date when a secondary processor reads it. Use the read-only
scheduler assignment instead.
Add a new fatal error SMP_FATAL_MULTITASKING_START_ON_INVALID_PROCESSOR.
This prevents out-of-bounds access.
It is currently not possible to test these fatal errors. One option
would be to fake values of the _CPU_SMP_Get_current_processor(), but
unfortunately this function is inline on some architectures.
Extract code from _Scheduler_SMP_Enqueue_ordered() and move it to the
new function _Scheduler_SMP_Enqueue_scheduled_ordered() to avoid
untestable execution paths.
Add and use function _Scheduler_SMP_Unblock().
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
This handler can be used to test the inter-processor interrupt
implementation.
Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it
a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
The thread restart is now supported on SMP. New test
smptests/smpthreadlife01.
This method exercises the ability to dynamically get and set
the affinity of POSIX threads.
NOTE: There is no scheduler support for affinity. This is
simply a data integrity test.
This test exercises the ability to obtain and modify
the affinity field of the POSIX thread attributes.
This test exercises the new Classic API task affinity methods.
New test smptests/smpfatal03.
