path: root/testsuites/samples (follow)
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-271-0/+2
| | | | more accurate.
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-2/+0
| | | | the CPU family name constants.
* updated copyright to 1998Joel Sherrill1998-02-1722-22/+22
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-232-0/+5
* Removed warning.Joel Sherrill1997-11-181-1/+1
* Fix from Eric Norum so FPSP is installed before any FP code is actuallyJoel Sherrill1997-10-081-0/+9
| | | | exercise.
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0823-46/+46
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-0/+6
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* updated with new license information per Tony Bennett.Joel Sherrill1997-04-221-13/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2222-110/+110
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-296-1/+10
| | | | or rtems initialization table in configuration table
* Increased stack size.Joel Sherrill1996-01-191-1/+3
* Init task was not defined as being floating point.Joel Sherrill1996-01-151-0/+2
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+2
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-2/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-193-8/+14
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1112-73/+115
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2311-11/+11
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-1712-27/+26
* Initial revisionJoel Sherrill1995-05-1130-0/+3231
