* | 2011-07-04 Chris Johns <chrisj@rtems.org> | Chris Johns | 2011-07-04 | 3 | -2/+540 |
| | | | | | * fileio/init.c, fileio/system.h: Add commands to create ram disks from the shell prompt. Helps testing. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 3 | -45/+9 |
| | | | | | * pppd/Makefile.am: Add ppp.conf, pppd.options to EXTRA_DIST. * pppd/Makefile-user: Remove. | ||||
* | 2011-06-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-11 | 2 | -6/+11 |
| | | | | | * fileio/init.c: Avoid use of deprecated rtems_clock_get() except in spclockget(). | ||||
* | 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-05-05 | 3 | -0/+9 |
| | | | | | * fileio/Makefile.am, ticker/Makefile.am: Missed part of previous patch. | ||||
* | 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-05-05 | 9 | -98/+45 |
| | | | | | | * base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h, nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove warnings. | ||||
* | Add config.h.in | Ralf Corsepius | 2011-03-01 | 1 | -0/+1 |
* | 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-22 | 2 | -1/+5 |
| | | | | * configure.ac: Add AC_CONFIG_HEADER(config.h). | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 23 | -0/+92 |
* | 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-22 | 1 | -0/+10 |
| | | | | | | | | | | * base_mp/apptask.c, base_mp/init.c, base_sp/apptask.c, base_sp/init.c, capture/init.c, capture/test1.c, cdtest/init.c, fileio/init.c, hello/init.c, loopback/init.c, minimum/init.c, nsecs/empty.c, nsecs/init.c, paranoia/init.c, paranoia/paranoia.c, pppd/init.c, pppd/pppdapp.c, ticker/init.c, ticker/tasks.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Add HAVE_CONFIG_H. | ||||
* | 2011-02-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-17 | 2 | -12/+14 |
| | | | | * pppd/system.h: Use confdefs.h to generate device driver table. | ||||
* | 2011-02-17 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Sebastian Huber | 2011-02-17 | 2 | -0/+6 |
| | | | | * pppd/system.h: Added missing include files. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -1/+5 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-12-08 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Sebastian Huber | 2010-12-08 | 2 | -19/+6 |
| | | | | | * loopback/init.c: Loop back interface will be initialized now during normal initialization via rtems_bsdnet_initialize_network(). | ||||
* | 2010-08-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-08-16 | 3 | -10/+8 |
| | | | | | | * fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP). * configure.ac: Remove AM_CONDITIONAL(LIBCHIP). Force autoconf-2.67, automake-1.11.1. | ||||
* | 2010-07-07 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Sebastian Huber | 2010-07-07 | 2 | -0/+23 |
| | | | | | * minimum/init.c: Use fatal error extension to prevent infinite runtime. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-21 | 2 | -3/+7 |
| | | | | * capture/capture.doc: Remove more ITRON references. | ||||
* | 2010-06-02 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-02 | 2 | -4/+4 |
| | | | | * iostream/init.cc: Remove the hack. | ||||
* | 2010-06-02 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-02 | 4 | -19/+32 |
| | | | | | | * fileio/init.c: Update to new mount API. * iostream/init.cc: Hack to work around confdefs.h in C++. * iostream/system.h: Add comment about base miniIMFS. | ||||
* | 2010-04-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-04 | 1 | -0/+4 |
| | | | | * capture/init.c: Remove unused variable "out". | ||||
* | Remove unused variable "out". | Ralf Corsepius | 2010-04-04 | 1 | -1/+0 |
* | exclude big samples for SMALL MEMORY BSPs | Thomas Doerfler | 2010-03-29 | 5 | -9/+19 |
* | 2010-03-12 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2010-03-12 | 2 | -23/+25 |
| | | | | * fileio/init.c: Remove deprecation warnings. | ||||
* | 2010-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-11 | 2 | -1/+5 |
| | | | | * fileio/init.c: Fix warnings for ctype methods. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 5 | -33/+33 |
* | 2009-11-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-02 | 1 | -0/+5 |
| | | | | | * loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to int to match with rtems/rtems_bsdnet.h. | ||||
* | Adjust return-type of rtems_bsdnet_loopattach to int to match with ↵ | Ralf Corsepius | 2009-11-02 | 1 | -1/+1 |
* | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-30 | 1 | -0/+7 |
| | | | | | | | * base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids. Include "tmacros.h". * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Add -I$(top_srcdir)/../support/include. | ||||
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-30 | 2 | -0/+2 |
* | Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 2009-10-30 | 1 | -2/+4 |
| | | | | Include "tmacros.h". | ||||
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -0/+2 |
| | | | | | * pppd/netconfig.h: Add UL suffix to long constants to avoid implicit integer overflows on 16bit targets. | ||||
* | Add UL suffix to long constants to avoid | Ralf Corsepius | 2009-10-29 | 1 | -2/+2 |
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 2 | -1/+5 |
| | | | | * fileio/init.c: Use %zd to print ssize_t. | ||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 |
| | | | | | * base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | ||||
* | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2009-10-27 | 2 | -3/+3 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+3 |
| | | | | | | * base_sp/apptask.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | ||||
* | Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 2009-10-26 | 5 | -11/+17 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+5 |
| | | | | | * unlimited/Makefile.am, base_sp/Makefile.am: Add -I$(top_srcdir)/../support/include. | ||||
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-26 | 2 | -0/+4 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+2 |
| | | | | | * loopback/init.c : Add prototype for rtems_bsdnet_loopattach. Remove evil type-cast. | ||||
* | Add prototype for rtems_bsdnet_loopattach. | Ralf Corsepius | 2009-10-26 | 1 | -2/+3 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+6 |
| | | | | | | * nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h). * nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include. * nsecs/init.c: Include "tmacros.h" instead of "rprintf.h" | ||||
* | Remove. | Ralf Corsepius | 2009-10-26 | 1 | -9/+0 |
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-26 | 1 | -1/+3 |
* | Include "tmacros.h" instead of "rprintf.h" | Ralf Corsepius | 2009-10-26 | 1 | -2/+1 |
* | Add rprintf.h | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | 2009-10-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-24 | 1 | -0/+15 |
| | | | | | | | | | | | | | | | * capture/init.c: Remove setup_tasks_to_watch. * capture/system.h: Remove test*(). Add setup_tasks_to_watch(). * capture/test1.c: Fix prototype. * fileio/init.c: Fix broken printfs. * minimum/init.c: Remove unused var. * nsecs/empty.c: Add missing prototype. * nsecs/rprintf.h: New. * nsecs/init.c: Printf fixes. * unlimited/system.h: Add missing prototypes. * unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Various warning fixes. | ||||
* | Various warning fixes. | Ralf Corsepius | 2009-10-24 | 4 | -19/+21 |
* | Add missing prototypes. | Ralf Corsepius | 2009-10-24 | 1 | -3/+3 |
* | Printf fixes. | Ralf Corsepius | 2009-10-24 | 1 | -5/+7 |
* | New. | Ralf Corsepius | 2009-10-24 | 1 | -0/+9 |
