path: root/testsuites/samples (follow)
* score: Simplify _Thread_Initialize()Sebastian Huber2020-02-121-0/+2
| | | | | | | | Allocate new thread queue heads during objects information extend. This removes an error case and the last dependency on the workspace in _Thread_Initialize(). Update #3835.
* samples/iostream: Simplify configurationSebastian Huber2020-02-061-1/+0
| | | | | Remove CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY since it is not needed and just increases the boot time.
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-194-4/+4
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* rtems: Add and use rtems_object_get_local_node()Sebastian Huber2019-12-131-1/+1
| | | | Update #3841.
* samples/paranoia: Remove <bsp.h> includeSebastian Huber2019-11-121-1/+0
| | | | This include is superfluous.
* samples: Avoid build system defined definesSebastian Huber2019-11-125-5/+13
| | | | Update #3818.
* ticker/init.c: Error should say clock set not getJoel Sherrill2019-07-221-1/+1
* build: Do not install test programsSebastian Huber2019-01-301-3/+1
* samples/pppd: Use less memory hungry configurationSebastian Huber2019-01-291-5/+4
| | | | This avoids link-time failures on some low memory BSPs.
* build: Add missing $(LDADD) for dependenciesSebastian Huber2019-01-141-1/+1
* score: Remove Objects_Information::auto_extendSebastian Huber2018-12-141-4/+4
| | | | | | | Use Objects_Information::objects_per_block to provide this information. Add and use _Objects_Is_auto_extend(). Update #3621.
* Correct minor spelling and grammar errorsZenon2018-11-061-2/+2
| | | | This work was performed as a GCI 2018 task.
* build: Remove local.amSebastian Huber2018-10-101-1/+0
* build: Directly reference libraries in testsSebastian Huber2018-10-101-1/+1
| | | | Remove use of TMPINSTALL_FILES.
* tests: Use rtems_task_exit()Sebastian Huber2018-10-0510-29/+26
| | | | Update #3533.
* fileio: Avoid deprecated rtems_disk_obtain()Sebastian Huber2018-08-071-22/+25
| | | | Update #3358.
* nvdisk: Use rtems_blkdev_create()Sebastian Huber2018-08-072-59/+3
| | | | Update #3358.
* ramdisk: Use rtems_blkdev_create()Sebastian Huber2018-08-071-59/+24
| | | | Update #3358.
* samples/minimum: Use default interrupt stack sizeSebastian Huber2018-07-251-0/+10
| | | | Update #3433.
* samples: Fix warningsSebastian Huber2018-07-242-2/+6
* capture: Use unlimited objectsSebastian Huber2018-06-041-3/+2
| | | | Avoid resource allocation problems with unlimited objects.
* tests: Remove configure feature checksSebastian Huber2018-05-021-26/+1
| | | | Update #3409.
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-111-1/+1
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* testsuite/samples: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-1022-372/+168
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* build: Remove EXTRA_DISTSebastian Huber2018-04-041-3/+0
| | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am.
* termios: Remove obsolete configuration optionsSebastian Huber2018-02-051-6/+0
| | | | Update #2843.
* Remove make preinstallChris Johns2018-01-253-0/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* cdtest: Increase stack sizeSebastian Huber2018-01-221-0/+3
* tests: Use rtems_test_begin and rtems_test_end.Chris Johns2017-11-111-2/+2
| | | | | | Add a tests enum and move all test banner test to the library in libmisc. Update #3199.
* pppd/Makefile.am: Add support/includeJoel Sherrill2017-11-091-0/+2
* tests: Use normal console for user input testsSebastian Huber2017-11-073-3/+3
* tests: Use <tmacros.h> in all testsSebastian Huber2017-11-069-60/+25
| | | | | Update #3170. Update #3199.
* tests: Use simple console driverSebastian Huber2017-11-0613-13/+13
* tests: Use printf() instead of fprintf()Sebastian Huber2017-11-021-25/+13
* tests: Remove TEST_INITSebastian Huber2017-10-2810-20/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* tests: Use rtems_print_printer_fprintf_putc()Sebastian Huber2017-10-285-5/+5
| | | | | | | | Use rtems_print_printer_fprintf_putc() instead of rtems_print_printer_printf() to output via rtems_putc(). Update #3170. Update #3199.
* tests: Move rtems_test_printer definitionSebastian Huber2017-10-285-5/+0
| | | | | | | Statically initialize it to use printk(). Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-2310-0/+20
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* samples/fileio: Give command availability hintSebastian Huber2017-08-241-3/+7
| | | | Close #3088.
* tests: Use floating point taskSebastian Huber2017-07-185-0/+9
| | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076.
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-042-16/+22
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* cdtest: Print begin of test only onceSebastian Huber2017-03-031-2/+0
* cdtest: Print proper begin/end of test messagesSebastian Huber2016-12-092-28/+56
* cdtest: Add std::runtime_error() test caseChris Johns2016-12-091-15/+26
| | | | Update #2830.
* tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEMSebastian Huber2016-09-191-1/+0
| | | | Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
* Move printer initialization to separate headerSebastian Huber2016-06-221-0/+1
| | | | | | The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>.
* Make rtems/print.h independent of rtems/bspIo.hSebastian Huber2016-06-221-0/+1
* samples/base_mp/apptask.c: Fix warning and clean upJoel Sherrill2016-06-161-12/+11
* testsuite: Fix networking samples to use the RTEMS printer.Chris Johns2016-05-262-0/+6
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-253-0/+6
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
