* capture/init.c: Remove setup_tasks_to_watch.
* capture/system.h: Remove test*().
Add setup_tasks_to_watch().
* capture/test1.c: Fix prototype.
* fileio/init.c: Fix broken printfs.
* minimum/init.c: Remove unused var.
* nsecs/empty.c: Add missing prototype.
* nsecs/rprintf.h: New.
* nsecs/init.c: Printf fixes.
* unlimited/system.h: Add missing prototypes.
* unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Various warning fixes.
* unlimited/test1.c: Spacing.
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* capture/test1.c: Use size_t for sizes.
* hello/Makefile.am, hello/init.c: Simplify.
* hello/system.h: Removed.
* unlimited/test2.c: Fix spacing.
* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c,
ticker/system.h, ticker/tasks.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to
legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to
rtems_clock_get_xxx().
* ticker/tasks.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* fileio/system.h: Switch to unified work area.
* cdtest/system.h: modified the number of max semaphores
- test was failing before
* loopback/init.c: Add missing initializers.
* iostream/system.h: Remove the Init prototype. Provide in
confdefs.h.
* fileio/init.c, fileio/system.h, iostream/init.cc,
loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if
BSP_SMALL_MEMORY is defined. Remove this code once a better way is
supported by the build system.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate _exe_/.exe.
* fileio/init.c: Change arguments to rtems_shell_init() to match
new expectations.
* cdtest/main.cc: Use printk() in global destructors since printf() no
longer works.
* capture/test1.c: Add const to eliminate warning.
* capture/test1.c: Eliminate all public use of TOD conversion routines.
* unlimited/init.c: Run all tests successfully with maxixum number of
priorities as 16 instead of 256. This was done by temporarily
modifying the score priority.h maximum. This allowed testing of all
API code to ensure that it worked properly with a reduced number of
priorities. Most modifications were to switch from hard-coded maximum
to using the API provided methods to determine maximum number of
priority levels.
* fileio/init.c: Add explicit creation of /etc/passwd and /etc/group so
we have a test case for real password checking.
* paranoia/paranoia.c: Add missing prototypes.
* unlimited/system.h: Tighten configuration for stack space.
* fileio/init.c: When USE_SHELL not defined, do not attempt to
configure shell.
* unlimited/system.h: 10000 task ids is too many for some targets.
* unlimited/system.h: Support up to 10K tasks in loop. With 64MB on
pc386 and configured for unified workspace, you can get close to
this.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* minimum/init.c, unlimited/system.h: Add support for optionally having
a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
* hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC
project code to add simple device only filesystem (devfs), optionally
completely drop out filesystem, and to clean up disabling newlib
reentrancy support. This dropped 17K from the minimum.exe for
sparc/sis and arm/rtl22xx_t now has a 15K code space.
* capture/system.h, capture/test1.c, fileio/init.c,
unlimited/init.c, unlimited/system.h, unlimited/test1.c:
Convert to "bool".
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Updating and
fixing while running mptests on psim.
* fileio/init.c: New argument sequence for rtems_shell_init(). Also
split on multiple lines and document each parameter.
