* minimum/init.c: Disable confdefs.h debug.
* iostream/system.h: Init task was close to blowing stack on PowerPC.
* minimum/init.c: Disable Classic API Notepads.
* minimum/init.c: Add CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY. Workspace usage now reduces to 4696 bytes
on psim.
* minimum/init.c: Exerise new ability for application to configure
minimum stack size. This test still runs the same with a 7.5K stack
on the powerpc but reserves 15K less Workspace on the PowerPC.
* minimum/Makefile.am: Link against all managers.
* minimum/init.c: Use existing confdefs.h macros to turn off more
this test does not use.
* iostream/system.h: Update to include definition of
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER as appropriate.
* fileio/init.c, hello/system.h, minimum/init.c, unlimited/system.h:
Use CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER where needed.
* iostream/init.cc: Add include of stdlib.h for exit(). Needed by gcc
4.3.x.
* fileio/system.h, ticker/system.h: Add new Object Services collection.
This changed the name of a few previously public but undocumented
services and added a some new services.
* hello/init.c: Remove accidental commit.
* fileio/init.c, fileio/system.h, hello/init.c: Enable malloc
statistics so shell output can be interesting.
* testsuites/samples/fileio/init.c: Change shell_* to
rtems_shell_*. Add the mount file-system type of msdos.
* fileio/init.c, fileio/system.h: Increase stack requested for shell
task. Turn on stack checking so the report is interesting.
* fileio/init.c: Add RTEMS Shell configuration and static configuration
of user commands.
* iostream/Makefile.am: Change the executable name so it does not
create a file which is the same name as the standard header file.
* iostream/system.h: Need to increase the number of semaphores for
the libstdc++ runtime.
* capture/Makefile.am: Use all managers.
* capture/Makefile.am: Fix typo -- not unlimited.
* capture/init.c, capture/system.h, capture/test1.c: Removed CRs
from files. Committed incorrectly.
* Makefile.am, README, configure.ac, capture/.cvsignore,
capture/Makefile.am, capture/capture.doc, capture/capture.scn,
capture/init.c, capture/system.h, capture/test1.c: Add a sample
test for the capture engine.
* nsecs/init.c: Add include of unistd.h for sleep() prototype.
* nsecs/Makefile.am, nsecs/init.c: Move empty body to another file. The
loop was being optimized out on the PowerPC.
* nsecs/empty.c: New file.
* nsecs/init.c: Change name to avoid any hint of the timer driver.
* nsecs/init.c: Do not make this test depend on the benchmark timer
driver.
* nsecs/init.c, nsecs/nsecs.scn: Add set of loops so you can see the
time varaying in proportion to the length of the loop measured.
* nsecs/init.c: Remove stray "volatile int i".
* base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, nsecs/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, ticker/system.h,
unlimited/Makefile.am: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
* nsecs/init.c: Commit hack so test will compile when POSIX is
disabled. Remove hack when clock_gettime() is present even when
--disable-posix.
* ticker/Makefile.am, ticker/init.c, ticker/system.h, ticker/tasks.c:
Test needs clock manager. Should use rtems_test_exit() instead of
exit().
* minimum/Makefile.am, minimum/init.c: Switch back to using optional
manager support. Also add use of CONFIGURE_DISABLE_NEWLIB_REENTRANCY
to demonstrate that the newlib reentrancy support is optional.
* nsecs/init.c: Remove private decl of _Timespec_Subtract use the
version from rtems/score/timespec.h.
* nsecs/init.c: Provide timespec manipulation routines in the
SuperCore. Use them everywhere possible. Perhaps they should be part
of the public API so this test and others can use them without
peeking into the bowels.
* loopback/init.c: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX
configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX.
* Makefile.am, configure.ac: Convert from Classic API style TOD_Control
as fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* nsecs/.cvsignore, nsecs/Makefile.am, nsecs/init.c, nsecs/nsecs.doc,
nsecs/nsecs.scn: New files.
* loopback/init.c: Add CVS Id.
PR 1230/tests
* minimum/init.c: Minimum should not configure console driver.
* loopback/init.c: Fix exit paths in client thread and main test
thread.
fixed synchronization bug between ata.c and bdbuf.c
PR 1162/rtems
* unlimited/system.h: Reserve enough memory for the stacks wanted.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir
instead.
* cdtest/main.cc: Fix warnings.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
