* | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-30 | 1 | -0/+7 |
| | | | | | | | * base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids. Include "tmacros.h". * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Add -I$(top_srcdir)/../support/include. | ||||
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-30 | 2 | -0/+2 |
* | Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 2009-10-30 | 1 | -2/+4 |
| | | | | Include "tmacros.h". | ||||
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -0/+2 |
| | | | | | * pppd/netconfig.h: Add UL suffix to long constants to avoid implicit integer overflows on 16bit targets. | ||||
* | Add UL suffix to long constants to avoid | Ralf Corsepius | 2009-10-29 | 1 | -2/+2 |
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 2 | -1/+5 |
| | | | | * fileio/init.c: Use %zd to print ssize_t. | ||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 |
| | | | | | * base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | ||||
* | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2009-10-27 | 2 | -3/+3 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+3 |
| | | | | | | * base_sp/apptask.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | ||||
* | Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 2009-10-26 | 5 | -11/+17 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+5 |
| | | | | | * unlimited/Makefile.am, base_sp/Makefile.am: Add -I$(top_srcdir)/../support/include. | ||||
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-26 | 2 | -0/+4 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+2 |
| | | | | | * loopback/init.c : Add prototype for rtems_bsdnet_loopattach. Remove evil type-cast. | ||||
* | Add prototype for rtems_bsdnet_loopattach. | Ralf Corsepius | 2009-10-26 | 1 | -2/+3 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+6 |
| | | | | | | * nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h). * nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include. * nsecs/init.c: Include "tmacros.h" instead of "rprintf.h" | ||||
* | Remove. | Ralf Corsepius | 2009-10-26 | 1 | -9/+0 |
* | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2009-10-26 | 1 | -1/+3 |
* | Include "tmacros.h" instead of "rprintf.h" | Ralf Corsepius | 2009-10-26 | 1 | -2/+1 |
* | Add rprintf.h | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | 2009-10-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-24 | 1 | -0/+15 |
| | | | | | | | | | | | | | | | * capture/init.c: Remove setup_tasks_to_watch. * capture/system.h: Remove test*(). Add setup_tasks_to_watch(). * capture/test1.c: Fix prototype. * fileio/init.c: Fix broken printfs. * minimum/init.c: Remove unused var. * nsecs/empty.c: Add missing prototype. * nsecs/rprintf.h: New. * nsecs/init.c: Printf fixes. * unlimited/system.h: Add missing prototypes. * unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Various warning fixes. | ||||
* | Various warning fixes. | Ralf Corsepius | 2009-10-24 | 4 | -19/+21 |
* | Add missing prototypes. | Ralf Corsepius | 2009-10-24 | 1 | -3/+3 |
* | Printf fixes. | Ralf Corsepius | 2009-10-24 | 1 | -5/+7 |
* | New. | Ralf Corsepius | 2009-10-24 | 1 | -0/+9 |
* | Add missing prototype. | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | Remove unused var. | Ralf Corsepius | 2009-10-24 | 1 | -2/+0 |
* | Fix broken prints. | Ralf Corsepius | 2009-10-24 | 1 | -2/+2 |
* | Fix prototype. | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | Remove test*(). | Ralf Corsepius | 2009-10-24 | 1 | -3/+1 |
| | | | | Add setup_tasks_to_watch(). | ||||
* | Remove setup_tasks_to_watch. | Ralf Corsepius | 2009-10-24 | 1 | -2/+0 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 1 | -1/+24 |
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -3/+7 |
| | | | | * unlimited/test1.c: Spacing. | ||||
* | 2009-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-02 | 2 | -1/+5 |
| | | | | | * hello/init.c: Remove call to devFS_Show() which had accidentally gotten committed. | ||||
* | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-14 | 2 | -1/+5 |
| | | | | * capture/test1.c: Use size_t for sizes. | ||||
* | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-26 | 4 | -43/+22 |
| | | | | | * hello/Makefile.am, hello/init.c: Simplify. * hello/system.h: Removed. | ||||
* | 2009-08-21 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2009-08-21 | 2 | -1/+5 |
| | | | | * unlimited/test2.c: Fix spacing. | ||||
* | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-12 | 7 | -28/+17 |
| | | | | | | | * cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c, ticker/system.h, ticker/tasks.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second(). | ||||
* | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-10 | 4 | -19/+22 |
| | | | | | | * fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx(). | ||||
* | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-10 | 2 | -2/+7 |
| | | | | | * ticker/tasks.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..). | ||||
* | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-10 | 2 | -1/+6 |
| | | | | * fileio/system.h: Switch to unified work area. | ||||
* | 2009-06-11 Roxana Leontie <roxana.leontie@gmail.com> | Chris Johns | 2009-06-12 | 2 | -1/+6 |
| | | | | | * cdtest/system.h: modified the number of max semaphores - test was failing before | ||||
* | 2009-06-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-06-04 | 2 | -0/+18 |
| | | | | * loopback/init.c: Add missing initializers. | ||||
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 2 | -6/+5 |
| | | | | | * iostream/system.h: Remove the Init prototype. Provide in confdefs.h. | ||||
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 7 | -7/+64 |
| | | | | | | | * fileio/init.c, fileio/system.h, iostream/init.cc, loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if BSP_SMALL_MEMORY is defined. Remove this code once a better way is supported by the build system. | ||||
* | removed obsolete references to login.h | Thomas Doerfler | 2009-04-14 | 2 | -1/+4 |
* | Eliminate _exe_/.exe. | Ralf Corsepius | 2009-04-03 | 15 | -106/+106 |
* | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-04-03 | 1 | -0/+9 |
| | | | | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Eliminate _exe_/.exe. | ||||
* | Fix Id string typo. | Joel Sherrill | 2009-03-29 | 1 | -2/+2 |
* | 2009-03-29 Joel Sherrill <joel.sherrill@gmail.com> | Joel Sherrill | 2009-03-29 | 2 | -2/+7 |
| | | | | | * fileio/init.c: Change arguments to rtems_shell_init() to match new expectations. | ||||
* | 2009-03-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-03-02 | 2 | -4/+10 |
| | | | | | * cdtest/main.cc: Use printk() in global destructors since printf() no longer works. |
