Allow the test to run and pass when automatic testing.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
Use posix keys for current shell environment instead of task variables. With
this patch the shell needs one posix-key and one posix-key-value-pair
configured.
Update documentation for the shell.
Adapt samples/fileio:
- Add necessary objects.
- Add login function and custom device name for better testing of the shell.
TOD_MILLISECONDS_TO_TICKS().
application visible API.
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
for details.
LINK_OBJS =
instead of
LINK_OBJS = $(mp01_node1_OBJECTS)
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros. Also adds new documentation in
the C User's Manual regarding configuring with unlimited objects.
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
* pppd/system.h: Add pppdapp_initialize.
* pppd/init.c: Remove pppdapp_initialize.
* nsecs/system.h: New (Split out from nsecs/init.c).
* nsecs/init.c: Reflect nsecs/system.h having been split out.
* nsecs/empty.c: Include "system.h".
* fileio/init.c: Comment out setup_nvdisk (Unused).
Make shell_nvdisk_trace, shell_nvdisk_erase, shell_bdbuf_trace,
disk_test_set_block_size, disk_test_write_blocks, disk_test_block_sizes,
parse_size_arg, create_ramdisk, create_nvdisk static.
* nsecs/init.c: Make my_ctime, subtract_em static.
PR 1589/build
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Remove obsolete optional manager capability.
* fileio/init.c: Explictly consts in size_t initializers
(avoid overflows on 16bit-int targets).
* capture/init.c: Declare notification only if being used.
* nsecs/init.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* configure.ac: Check for size of time_t.
* fileio/fileio.scn: New file.
* capture/init.c, fileio/init.c: Use rtems_shell_wait_for_input().
* ticker/system.h: Remove unneeded include.
* fileio/init.c, fileio/system.h: Add commands to
create ram disks from the shell prompt. Helps testing.
* pppd/Makefile.am: Add ppp.conf, pppd.options to EXTRA_DIST.
* pppd/Makefile-user: Remove.
* fileio/init.c: Avoid use of deprecated rtems_clock_get() except in
spclockget().
* fileio/Makefile.am, ticker/Makefile.am: Missed part of previous
patch.
* base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h,
nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove
warnings.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
