with ITRON 3.0 data types regardless of how dumb it is to name
types with a simple letter.
BSP needs to be eliminated.
of space in the workspace.
and RTEMS configuration.
<rdasilva@connecttel.com>.
are:
more accurate.
the CPU family name constants.
exercise.
like signal dispatching.
