path: root/testsuites/samples (follow)
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-041-0/+2
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Modified to use minimum stack size and reserve the necessary amountJoel Sherrill1999-11-025-7/+13
| | | | of space in the workspace.
* Increased stack space of a task.Joel Sherrill1999-11-012-3/+5
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-4/+4
* New configuration files added by patch fromJoel Sherrill1999-08-101-0/+27
| | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>".
* Added simple test to find minimum code size of executive with this BSPJoel Sherrill1999-05-173-0/+50
| | | | and RTEMS configuration.
* Added testing for C++ exceptions from Rosimildo DaSilvaJoel Sherrill1999-05-141-17/+90
| | | | <rdasilva@connecttel.com>.
* Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows:Joel Sherrill1999-03-177-0/+1068
| | | | | | | | | | | | | | | | | | | | | | | | | First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you.
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-271-0/+2
| | | | more accurate.
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-2/+0
| | | | the CPU family name constants.
* updated copyright to 1998Joel Sherrill1998-02-1722-22/+22
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-232-0/+5
* Removed warning.Joel Sherrill1997-11-181-1/+1
* Fix from Eric Norum so FPSP is installed before any FP code is actuallyJoel Sherrill1997-10-081-0/+9
| | | | exercise.
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0823-46/+46
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-0/+6
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* updated with new license information per Tony Bennett.Joel Sherrill1997-04-221-13/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2222-110/+110
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-296-1/+10
| | | | or rtems initialization table in configuration table
* Increased stack size.Joel Sherrill1996-01-191-1/+3
* Init task was not defined as being floating point.Joel Sherrill1996-01-151-0/+2
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+2
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-2/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-193-8/+14
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1112-73/+115
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2311-11/+11
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-1712-27/+26
* Initial revisionJoel Sherrill1995-05-1130-0/+3231
