for details.
LINK_OBJS =
instead of
LINK_OBJS = $(mp01_node1_OBJECTS)
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros. Also adds new documentation in
the C User's Manual regarding configuring with unlimited objects.
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
* pppd/system.h: Add pppdapp_initialize.
* pppd/init.c: Remove pppdapp_initialize.
* nsecs/system.h: New (Split out from nsecs/init.c).
* nsecs/init.c: Reflect nsecs/system.h having been split out.
* nsecs/empty.c: Include "system.h".
* fileio/init.c: Comment out setup_nvdisk (Unused).
Make shell_nvdisk_trace, shell_nvdisk_erase, shell_bdbuf_trace,
disk_test_set_block_size, disk_test_write_blocks, disk_test_block_sizes,
parse_size_arg, create_ramdisk, create_nvdisk static.
* nsecs/init.c: Make my_ctime, subtract_em static.
PR 1589/build
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Remove obsolete optional manager capability.
* fileio/init.c: Explictly consts in size_t initializers
(avoid overflows on 16bit-int targets).
* capture/init.c: Declare notification only if being used.
* nsecs/init.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* configure.ac: Check for size of time_t.
* fileio/fileio.scn: New file.
* capture/init.c, fileio/init.c: Use rtems_shell_wait_for_input().
* ticker/system.h: Remove unneeded include.
* fileio/init.c, fileio/system.h: Add commands to
create ram disks from the shell prompt. Helps testing.
* pppd/Makefile.am: Add ppp.conf, pppd.options to EXTRA_DIST.
* pppd/Makefile-user: Remove.
* fileio/init.c: Avoid use of deprecated rtems_clock_get() except in
spclockget().
* fileio/Makefile.am, ticker/Makefile.am: Missed part of previous
patch.
* base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h,
nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove
warnings.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* base_mp/apptask.c, base_mp/init.c, base_sp/apptask.c, base_sp/init.c,
capture/init.c, capture/test1.c, cdtest/init.c, fileio/init.c,
hello/init.c, loopback/init.c, minimum/init.c, nsecs/empty.c,
nsecs/init.c, paranoia/init.c, paranoia/paranoia.c, pppd/init.c,
pppd/pppdapp.c, ticker/init.c, ticker/tasks.c, unlimited/init.c,
unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Add
HAVE_CONFIG_H.
* pppd/system.h: Use confdefs.h to generate device driver table.
* pppd/system.h: Added missing include files.
* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP).
* configure.ac: Remove AM_CONDITIONAL(LIBCHIP).
Force autoconf-2.67, automake-1.11.1.
* minimum/init.c: Use fatal error extension to prevent infinite
runtime.
* capture/capture.doc: Remove more ITRON references.
* iostream/init.cc: Remove the hack.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* capture/init.c: Remove unused variable "out".
* fileio/init.c: Remove deprecation warnings.
* fileio/init.c: Fix warnings for ctype methods.
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to
int to match with rtems/rtems_bsdnet.h.
* base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids.
Include "tmacros.h".
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Add -I$(top_srcdir)/../support/include.
* pppd/netconfig.h: Add UL suffix to long constants to avoid
implicit integer overflows on 16bit targets.
* fileio/init.c: Use %zd to print ssize_t.
* base_sp/apptask.c, unlimited/init.c:
Use PRIdrtems_task_argument to print rtems_task_argument's.
