* | 2007-02-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-02-21 | 2 | -1/+9 |
| | | | | | * loopback/init.c: Fix exit paths in client thread and main test thread. | ||||
* | corrected bug in ata.c to avoid lockup of libblock | Thomas Doerfler | 2006-12-18 | 2 | -0/+12 |
| | | | | added remote frequest support to gen5200 BSP | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-19 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-19 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake-1.10. Require autoconf-2.60. | ||||
* | 2006-09-08 Ken Peters <ken.peters@jpl.nasa.gov> | Joel Sherrill | 2006-09-08 | 2 | -1/+6 |
| | | | | | PR 1162/rtems * unlimited/system.h: Reserve enough memory for the stacks wanted. | ||||
* | fixed system.h: only include ATA/IDE driver, when BSP supports an ide interface | Thomas Doerfler | 2006-07-11 | 1 | -0/+4 |
* | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | 2006-07-11 | 12 | -40/+20 |
* | 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 1 | -0/+9 |
| | | | | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead. | ||||
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 1 | -23/+2 |
* | Fix formatting. | Joel Sherrill | 2006-02-08 | 1 | -1/+1 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -2/+6 |
| | | | | * cdtest/main.cc: Fix warnings. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 2 | -1/+5 |
| | | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | Remove extraneous make-exe. | Eric Norum | 2005-11-16 | 1 | -0/+4 |
* | Remove erroneous make-exe. | Eric Norum | 2005-11-16 | 1 | -1/+0 |
* | Remove offending make-exe. | Eric Norum | 2005-11-15 | 1 | -1/+0 |
* | Fix my email address | Ralf Corsepius | 2005-11-13 | 1 | -6/+6 |
* | Convert to using *_PROGRAMS. | Ralf Corsepius | 2005-11-13 | 13 | -154/+115 |
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+9 |
| | | | | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Convert to using *_PROGRAMS. | ||||
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -8/+9 |
| | | | | * configure.ac: Remove AMPOLISH3. | ||||
* | Remove AMPOLISH3 | Ralf Corsepius | 2005-11-11 | 1 | -4/+0 |
* | Rework. | Ralf Corsepius | 2005-11-11 | 2 | -54/+14 |
* | * base_mp/node1/Makefile.am: Rework. | Ralf Corsepius | 2005-11-11 | 1 | -0/+10 |
| | | | | | | | | | | | | | | | * base_mp/node2/Makefile.am: Rework. * base_sp/Makefile.am: Rework. * cdtest/Makefile.am: Rework. * fileio/Makefile.am: Rework. * hello/Makefile.am: Rework. * iostream/Makefile.am: Rework. * loopback/Makefile.am: Rework. * minimum/Makefile.am: Rework. * paranoia/Makefile.am: Rework. * pppd/Makefile.am: Rework. * ticker/Makefile.am: Rework. * unlimited/Makefile.am: Rework. | ||||
* | Rework. | Ralf Corsepius | 2005-11-11 | 11 | -294/+71 |
* | Cosmetics. | Ralf Corsepius | 2005-11-11 | 13 | -40/+0 |
* | Hard-code node number. | Ralf Corsepius | 2005-11-11 | 2 | -16/+14 |
* | Eliminate TEST. | Ralf Corsepius | 2005-11-11 | 13 | -90/+77 |
* | Remove. | Ralf Corsepius | 2005-11-11 | 1 | -22/+0 |
* | Expand sample.am. | Ralf Corsepius | 2005-11-11 | 13 | -13/+260 |
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -0/+9 |
| | | | | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Expand sample.am. * sample.am: Remove. | ||||
* | Eliminate DOCTYPES. | Ralf Corsepius | 2005-11-10 | 10 | -20/+10 |
* | 2005-11-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-10 | 1 | -1/+7 |
| | | | | | | | | * base_mp/node1/base_mp.doc, base_mp/node1/base_mp.scn, base_mp/node2/base_mp.doc, base_mp/node2/base_mp.scn: Remove. * base_mp/node1/base_mp-node1.doc, base_mp/node1/base_mp-node1.scn, base_mp/node2/base_mp-node2.doc, base_mp/node2/base_mp-node2.scn: New (Renamed from base_mp.*). | ||||
* | New. | Ralf Corsepius | 2005-11-10 | 4 | -0/+34 |
* | Remove. | Ralf Corsepius | 2005-11-10 | 4 | -34/+0 |
* | s/SAMPLE/TEST/ for improved consistency with other tests. | Ralf Corsepius | 2005-11-10 | 2 | -6/+4 |
* | s/SAMPLE/TEST/ for improved consistency with other tests. | Ralf Corsepius | 2005-11-10 | 2 | -2/+2 |
* | 2005-11-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-10 | 1 | -0/+8 |
| | | | | | | | | * sample.am, base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: s/SAMPLE/TEST/ for improved consistency with other tests. | ||||
* | s/SAMPLE/TEST/ for improved consistency with other tests. | Ralf Corsepius | 2005-11-10 | 12 | -36/+36 |
* | Build lib.a conditionally. | Ralf Corsepius | 2005-11-10 | 1 | -3/+3 |
* | 2005-11-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-10 | 1 | -0/+5 |
| | | | | | * configure.ac: Add ampolish3. * base_mp/Makefile.am: Remove redundant EXTRA_DIST. | ||||
* | Remove redundant EXTRA_DIST. | Ralf Corsepius | 2005-11-10 | 1 | -2/+1 |
* | Add ampolish3. | Ralf Corsepius | 2005-11-10 | 1 | -0/+4 |
* | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | 2005-11-09 | 1 | -0/+2 |
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+4 |
| | | | | * cdtest/Makefile.am: AM_CPPFLAGS += -I..../support/include. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 2 | -5/+5 |
| | | | | * configure.ac: Apply RTEMS_CHECK_CPUOPTS. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 2 | -1/+5 |
| | | | | * sample.am: Set project_bspdir=$(PROJECT_ROOT) | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 2 | -4/+8 |
| | | | | * sample.am: Remove LIB_VARIANT. | ||||
* | Cleanup | Ralf Corsepius | 2005-11-07 | 2 | -2/+2 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+9 |
| | | | | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am ticker/Makefile.am, unlimited/Makefile.am: Remove SRCS, PRINT_SRCS. | ||||
* | Remove SRCS, PRINT_SRCS. | Ralf Corsepius | 2005-11-07 | 13 | -25/+0 |
* | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 2005-11-07 | 15 | -15/+16 |
