2010-07-07 | 2010-07-07 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Sebastian Huber | 2 | -0/+23 | |
* minimum/init.c: Use fatal error extension to prevent infinite runtime. | |||||
2010-06-21 | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -3/+7 | |
* capture/capture.doc: Remove more ITRON references. | |||||
2010-06-02 | 2010-06-02 Chris Johns <chrisj@rtems.org> | Chris Johns | 2 | -4/+4 | |
* iostream/init.cc: Remove the hack. | |||||
2010-06-02 | 2010-06-02 Chris Johns <chrisj@rtems.org> | Chris Johns | 4 | -19/+32 | |
* fileio/init.c: Update to new mount API. * iostream/init.cc: Hack to work around confdefs.h in C++. * iostream/system.h: Add comment about base miniIMFS. | |||||
2010-04-04 | 2010-04-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* capture/init.c: Remove unused variable "out". | |||||
2010-04-04 | Remove unused variable "out". | Ralf Corsepius | 1 | -1/+0 | |
2010-03-29 | exclude big samples for SMALL MEMORY BSPs | Thomas Doerfler | 5 | -9/+19 | |
2010-03-12 | 2010-03-12 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2 | -23/+25 | |
* fileio/init.c: Remove deprecation warnings. | |||||
2010-03-11 | 2010-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* fileio/init.c: Fix warnings for ctype methods. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 5 | -33/+33 | |
2009-11-02 | 2009-11-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to int to match with rtems/rtems_bsdnet.h. | |||||
2009-11-02 | Adjust return-type of rtems_bsdnet_loopattach to int to match with ↵ | Ralf Corsepius | 1 | -1/+1 | |
2009-10-30 | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids. Include "tmacros.h". * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Add -I$(top_srcdir)/../support/include. | |||||
2009-10-30 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2 | -0/+2 | |
2009-10-30 | Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 1 | -2/+4 | |
Include "tmacros.h". | |||||
2009-10-29 | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* pppd/netconfig.h: Add UL suffix to long constants to avoid implicit integer overflows on 16bit targets. | |||||
2009-10-29 | Add UL suffix to long constants to avoid | Ralf Corsepius | 1 | -2/+2 | |
2009-10-29 | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* fileio/init.c: Use %zd to print ssize_t. | |||||
2009-10-27 | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | |||||
2009-10-27 | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2 | -3/+3 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+3 | |
* base_sp/apptask.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | |||||
2009-10-26 | Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 5 | -11/+17 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* unlimited/Makefile.am, base_sp/Makefile.am: Add -I$(top_srcdir)/../support/include. | |||||
2009-10-26 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2 | -0/+4 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* loopback/init.c : Add prototype for rtems_bsdnet_loopattach. Remove evil type-cast. | |||||
2009-10-26 | Add prototype for rtems_bsdnet_loopattach. | Ralf Corsepius | 1 | -2/+3 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h). * nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include. * nsecs/init.c: Include "tmacros.h" instead of "rprintf.h" | |||||
2009-10-26 | Remove. | Ralf Corsepius | 1 | -9/+0 | |
2009-10-26 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 1 | -1/+3 | |
2009-10-26 | Include "tmacros.h" instead of "rprintf.h" | Ralf Corsepius | 1 | -2/+1 | |
2009-10-24 | Add rprintf.h | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | 2009-10-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+15 | |
* capture/init.c: Remove setup_tasks_to_watch. * capture/system.h: Remove test*(). Add setup_tasks_to_watch(). * capture/test1.c: Fix prototype. * fileio/init.c: Fix broken printfs. * minimum/init.c: Remove unused var. * nsecs/empty.c: Add missing prototype. * nsecs/rprintf.h: New. * nsecs/init.c: Printf fixes. * unlimited/system.h: Add missing prototypes. * unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Various warning fixes. | |||||
2009-10-24 | Various warning fixes. | Ralf Corsepius | 4 | -19/+21 | |
2009-10-24 | Add missing prototypes. | Ralf Corsepius | 1 | -3/+3 | |
2009-10-24 | Printf fixes. | Ralf Corsepius | 1 | -5/+7 | |
2009-10-24 | New. | Ralf Corsepius | 1 | -0/+9 | |
2009-10-24 | Add missing prototype. | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | Remove unused var. | Ralf Corsepius | 1 | -2/+0 | |
2009-10-24 | Fix broken prints. | Ralf Corsepius | 1 | -2/+2 | |
2009-10-24 | Fix prototype. | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | Remove test*(). | Ralf Corsepius | 1 | -3/+1 | |
Add setup_tasks_to_watch(). | |||||
2009-10-24 | Remove setup_tasks_to_watch. | Ralf Corsepius | 1 | -2/+0 | |
2009-10-21 | interrupt handler type change | Thomas Doerfler | 1 | -1/+24 | |
2009-10-14 | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -3/+7 | |
* unlimited/test1.c: Spacing. | |||||
2009-10-02 | 2009-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* hello/init.c: Remove call to devFS_Show() which had accidentally gotten committed. | |||||
2009-09-14 | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* capture/test1.c: Use size_t for sizes. | |||||
2009-08-26 | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -43/+22 | |
* hello/Makefile.am, hello/init.c: Simplify. * hello/system.h: Removed. | |||||
2009-08-21 | 2009-08-21 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2 | -1/+5 | |
* unlimited/test2.c: Fix spacing. | |||||
2009-08-12 | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 7 | -28/+17 | |
* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c, ticker/system.h, ticker/tasks.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second(). | |||||
2009-08-10 | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -19/+22 | |
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx(). |
