2009-11-02 | 2009-11-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to int to match with rtems/rtems_bsdnet.h. | |||||
2009-11-02 | Adjust return-type of rtems_bsdnet_loopattach to int to match with ↵ | Ralf Corsepius | 1 | -1/+1 | |
2009-10-30 | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids. Include "tmacros.h". * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Add -I$(top_srcdir)/../support/include. | |||||
2009-10-30 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2 | -0/+2 | |
2009-10-30 | Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 1 | -2/+4 | |
Include "tmacros.h". | |||||
2009-10-29 | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* pppd/netconfig.h: Add UL suffix to long constants to avoid implicit integer overflows on 16bit targets. | |||||
2009-10-29 | Add UL suffix to long constants to avoid | Ralf Corsepius | 1 | -2/+2 | |
2009-10-29 | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* fileio/init.c: Use %zd to print ssize_t. | |||||
2009-10-27 | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | |||||
2009-10-27 | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2 | -3/+3 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+3 | |
* base_sp/apptask.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | |||||
2009-10-26 | Include "tmacros.h". Use PRIxrtems_id to print rtems_ids. | Ralf Corsepius | 5 | -11/+17 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* unlimited/Makefile.am, base_sp/Makefile.am: Add -I$(top_srcdir)/../support/include. | |||||
2009-10-26 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 2 | -0/+4 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* loopback/init.c : Add prototype for rtems_bsdnet_loopattach. Remove evil type-cast. | |||||
2009-10-26 | Add prototype for rtems_bsdnet_loopattach. | Ralf Corsepius | 1 | -2/+3 | |
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h). * nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include. * nsecs/init.c: Include "tmacros.h" instead of "rprintf.h" | |||||
2009-10-26 | Remove. | Ralf Corsepius | 1 | -9/+0 | |
2009-10-26 | Add -I$(top_srcdir)/../support/include. | Ralf Corsepius | 1 | -1/+3 | |
2009-10-26 | Include "tmacros.h" instead of "rprintf.h" | Ralf Corsepius | 1 | -2/+1 | |
2009-10-24 | Add rprintf.h | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | 2009-10-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+15 | |
* capture/init.c: Remove setup_tasks_to_watch. * capture/system.h: Remove test*(). Add setup_tasks_to_watch(). * capture/test1.c: Fix prototype. * fileio/init.c: Fix broken printfs. * minimum/init.c: Remove unused var. * nsecs/empty.c: Add missing prototype. * nsecs/rprintf.h: New. * nsecs/init.c: Printf fixes. * unlimited/system.h: Add missing prototypes. * unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Various warning fixes. | |||||
2009-10-24 | Various warning fixes. | Ralf Corsepius | 4 | -19/+21 | |
2009-10-24 | Add missing prototypes. | Ralf Corsepius | 1 | -3/+3 | |
2009-10-24 | Printf fixes. | Ralf Corsepius | 1 | -5/+7 | |
2009-10-24 | New. | Ralf Corsepius | 1 | -0/+9 | |
2009-10-24 | Add missing prototype. | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | Remove unused var. | Ralf Corsepius | 1 | -2/+0 | |
2009-10-24 | Fix broken prints. | Ralf Corsepius | 1 | -2/+2 | |
2009-10-24 | Fix prototype. | Ralf Corsepius | 1 | -1/+1 | |
2009-10-24 | Remove test*(). | Ralf Corsepius | 1 | -3/+1 | |
Add setup_tasks_to_watch(). | |||||
2009-10-24 | Remove setup_tasks_to_watch. | Ralf Corsepius | 1 | -2/+0 | |
2009-10-21 | interrupt handler type change | Thomas Doerfler | 1 | -1/+24 | |
2009-10-14 | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -3/+7 | |
* unlimited/test1.c: Spacing. | |||||
2009-10-02 | 2009-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* hello/init.c: Remove call to devFS_Show() which had accidentally gotten committed. | |||||
2009-09-14 | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* capture/test1.c: Use size_t for sizes. | |||||
2009-08-26 | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -43/+22 | |
* hello/Makefile.am, hello/init.c: Simplify. * hello/system.h: Removed. | |||||
2009-08-21 | 2009-08-21 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2 | -1/+5 | |
* unlimited/test2.c: Fix spacing. | |||||
2009-08-12 | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 7 | -28/+17 | |
* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c, ticker/system.h, ticker/tasks.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second(). | |||||
2009-08-10 | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -19/+22 | |
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx(). | |||||
2009-08-10 | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -2/+7 | |
* ticker/tasks.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..). | |||||
2009-08-10 | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* fileio/system.h: Switch to unified work area. | |||||
2009-06-12 | 2009-06-11 Roxana Leontie <roxana.leontie@gmail.com> | Chris Johns | 2 | -1/+6 | |
* cdtest/system.h: modified the number of max semaphores - test was failing before | |||||
2009-06-04 | 2009-06-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -0/+18 | |
* loopback/init.c: Add missing initializers. | |||||
2009-04-28 | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2 | -6/+5 | |
* iostream/system.h: Remove the Init prototype. Provide in confdefs.h. | |||||
2009-04-28 | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 7 | -7/+64 | |
* fileio/init.c, fileio/system.h, iostream/init.cc, loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if BSP_SMALL_MEMORY is defined. Remove this code once a better way is supported by the build system. | |||||
2009-04-14 | removed obsolete references to login.h | Thomas Doerfler | 2 | -1/+4 | |
2009-04-03 | Eliminate _exe_/.exe. | Ralf Corsepius | 15 | -106/+106 | |
2009-04-03 | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+9 | |
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Eliminate _exe_/.exe. | |||||
2009-03-29 | Fix Id string typo. | Joel Sherrill | 1 | -2/+2 | |
