* base_sp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cdtest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* hello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* loopback/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* minimum/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* paranoia/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* pppd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* ticker/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* unlimited/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/init.c, fileio/system.h, ticker/system.h, ticker/tasks.c,
unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Convert to using c99 fixed size types.
* base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* base_mp/node2/Makefile.am: Ditto.
* base_sp/Makefile.am: Ditto.
* cdtest/Makefile.am: Ditto.
* fileio/Makefile.am: Ditto.
* hello/Makefile.am: Ditto.
* loopback/Makefile.am: Ditto.
* minimum/Makefile.am: Ditto.
* paranoia/Makefile.am: Ditto.
* pppd/Makefile.am: Ditto.
* ticker/Makefile.am: Ditto.
* unlimited/Makefile.am: Ditto.
* base_mp/Makefile.am: Reformat.
* base_mp/node1/Makefile.am: Remove all-local: $(ARCH).
* base_mp/node2/Makefile.am: Remove all-local: $(ARCH).
* base_sp/Makefile.am: Remove all-local: $(ARCH).
* cdtest/Makefile.am: Remove all-local: $(ARCH).
* fileio/Makefile.am: Remove all-local: $(ARCH).
* hello/Makefile.am: Remove all-local: $(ARCH).
* loopback/Makefile.am: Remove all-local: $(ARCH).
* minimum/Makefile.am: Remove all-local: $(ARCH).
* paranoia/Makefile.am: Remove all-local: $(ARCH).
* pppd/Makefile.am: Remove all-local: $(ARCH).
* ticker/Makefile.am: Remove all-local: $(ARCH).
* unlimited/Makefile.am: Remove all-local: $(ARCH).
* README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h,
base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc,
base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c,
base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h,
fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc,
hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc,
paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h,
ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc,
unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL
for license changed.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* unlimited/system.h, unlimited/test1.c: Backed off previous
modification as it does not compile.
* unlimited/test1.c: PR296. Only fails if more tasks than allowed
can be created.
* unlimited/system.h: PR296. Reference the number of tasks in the
configuration table rather than a hardcoded number.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/test1.c: Corrected use of _Objects_Information_table
now that it is a two dimensional array based upon API and class.
* base_sp/apptask.c: Include <stdlib.h>.
* hello/init.c: Ditto.
* paranoia/init.c: Ditto.
* ticker/tasks.c: Ditto.
* unlimited/init.c: Ditto.
* unlimited/test1.c: Ditto.
* unlimited/test2.c: Ditto.
* unlimited/test3.c: Ditto.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/init.c, unlimited/system.h, unlimited/test1.c,
Fixed typo.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
to convert the sample tests to automake.
of space in the workspace.
are:
