path: root/testsuites/samples/unlimited/system.h (follow)
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-1/+0
| | | | | | * unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: Fixed typo.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-7/+3
* Modified to use minimum stack size and reserve the necessary amountJoel Sherrill1999-11-021-3/+5
| | | | of space in the workspace.
* Unlimited objects patch from Chris Johns <ccj@acm.org>. Email follows:Joel Sherrill1999-03-171-0/+93
First, the unlimited patch. I have compiled the unlmited patch for the Linux posix BSP only and it seems to work cleanly. I would like a really major application run on this change before commiting as the changes are very core and significant. I am currently building all the tests to run. I have no targets suitable to test on at the moment. I have tested the patch for inline functions and macros. Turning macros on has found some core bugs. I have fixed these but have not run all the tests. Please review the patch for these changes. They are: 1) The conditional compilation for MP support broke the core messages code. You cannot embed a conditional macro in another macro. The Send and Urgent Send calls are macros. 2) User extensions handler initialisation now has two parameters. I have updated the macros to support the extra parameter. The patch also contains the gcc-target-default.cfg fix required to build the kernel. More of a by product than a fix for you.
