for details.
PR 1589/build
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Remove obsolete optional manager capability.
* base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, nsecs/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, ticker/system.h,
unlimited/Makefile.am: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
* nsecs/init.c: Commit hack so test will compile when POSIX is
disabled. Remove hack when clock_gettime() is present even when
--disable-posix.
* base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* base_mp/node2/Makefile.am: Ditto.
* base_sp/Makefile.am: Ditto.
* cdtest/Makefile.am: Ditto.
* fileio/Makefile.am: Ditto.
* hello/Makefile.am: Ditto.
* loopback/Makefile.am: Ditto.
* minimum/Makefile.am: Ditto.
* paranoia/Makefile.am: Ditto.
* pppd/Makefile.am: Ditto.
* ticker/Makefile.am: Ditto.
* unlimited/Makefile.am: Ditto.
* base_mp/Makefile.am: Reformat.
* base_mp/node1/Makefile.am: Remove all-local: $(ARCH).
* base_mp/node2/Makefile.am: Remove all-local: $(ARCH).
* base_sp/Makefile.am: Remove all-local: $(ARCH).
* cdtest/Makefile.am: Remove all-local: $(ARCH).
* fileio/Makefile.am: Remove all-local: $(ARCH).
* hello/Makefile.am: Remove all-local: $(ARCH).
* loopback/Makefile.am: Remove all-local: $(ARCH).
* minimum/Makefile.am: Remove all-local: $(ARCH).
* paranoia/Makefile.am: Remove all-local: $(ARCH).
* pppd/Makefile.am: Remove all-local: $(ARCH).
* ticker/Makefile.am: Remove all-local: $(ARCH).
* unlimited/Makefile.am: Remove all-local: $(ARCH).
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
to convert the sample tests to automake.
