base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
PR 451/bsps
* pppd/system.h: Depend on TTY driver being in BSPs not simply i386.
* fileio/Makefile.am: Remove references to *.scn (Doesn't exist).
* pppd/Makefile.am: Remove references to DOC* (Don't exist).
* pppd/system.h: Hack from Ralf to compile on all targets.
Adding pppd:
* pppd/Makefile-user: New, copied over from libnetworking/pppd/example.
* pppd/README: New, copied over from libnetworking/pppd/example.
* pppd/init.c: New, copied over from libnetworking/pppd/example.
* pppd/netconfig.h: New, copied over from libnetworking/pppd/example.
* pppd/ppp.conf: New, copied over from libnetworking/pppd/example.
* pppd/pppdapp.c: New, copied over from libnetworking/pppd/example.
* pppd/system.h: New, copied over from libnetworking/pppd/example.
* pppd/pppd.options: New, copied over from libnetworking/pppd/example.
* pppd/Makefile.am: New, converted to automake from Makefile-user.
* pppd/.cvsignore: New.
