Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
call to printk.
Updates #3170.
of this patch set.
* README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h,
base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc,
base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c,
base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h,
fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc,
hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc,
paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h,
ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc,
unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL
for license changed.
* base_sp/apptask.c: Include <stdlib.h>.
* hello/init.c: Ditto.
* paranoia/init.c: Ditto.
* ticker/tasks.c: Ditto.
* unlimited/init.c: Ditto.
* unlimited/test1.c: Ditto.
* unlimited/test2.c: Ditto.
* unlimited/test3.c: Ditto.
exercise.
like signal dispatching.
