* base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h,
nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove
warnings.
* nsecs/init.c: Add include of unistd.h for sleep() prototype.
* nsecs/Makefile.am, nsecs/init.c: Move empty body to another file. The
loop was being optimized out on the PowerPC.
* nsecs/empty.c: New file.
* nsecs/init.c: Change name to avoid any hint of the timer driver.
* nsecs/init.c: Do not make this test depend on the benchmark timer
driver.
* nsecs/init.c, nsecs/nsecs.scn: Add set of loops so you can see the
time varaying in proportion to the length of the loop measured.
* nsecs/init.c: Remove stray "volatile int i".
* base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, nsecs/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, ticker/system.h,
unlimited/Makefile.am: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
* nsecs/init.c: Commit hack so test will compile when POSIX is
disabled. Remove hack when clock_gettime() is present even when
--disable-posix.
* nsecs/init.c: Remove private decl of _Timespec_Subtract use the
version from rtems/score/timespec.h.
* nsecs/init.c: Provide timespec manipulation routines in the
SuperCore. Use them everywhere possible. Perhaps they should be part
of the public API so this test and others can use them without
peeking into the bowels.
* Makefile.am, configure.ac: Convert from Classic API style TOD_Control
as fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* nsecs/.cvsignore, nsecs/Makefile.am, nsecs/init.c, nsecs/nsecs.doc,
nsecs/nsecs.scn: New files.
