* iostream/init.cc: Remove the hack.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* iostream/system.h: Remove the Init prototype. Provide in
confdefs.h.
* fileio/init.c, fileio/system.h, iostream/init.cc,
loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if
BSP_SMALL_MEMORY is defined. Remove this code once a better way is
supported by the build system.
* iostream/system.h: Init task was close to blowing stack on PowerPC.
* minimum/init.c: Disable Classic API Notepads.
* iostream/system.h: Update to include definition of
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER as appropriate.
* iostream/init.cc: Add include of stdlib.h for exit(). Needed by gcc
4.3.x.
* iostream/Makefile.am: Change the executable name so it does not
create a file which is the same name as the standard header file.
* iostream/system.h: Need to increase the number of semaphores for
the libstdc++ runtime.
* base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, nsecs/Makefile.am,
pppd/Makefile.am, ticker/Makefile.am, ticker/system.h,
unlimited/Makefile.am: Add optional managers to Makefiles. Clean up
test cases so last output line follows END OF pattern. Make sure test
case all run. All tests appeared ok on sis.
* nsecs/init.c: Commit hack so test will compile when POSIX is
disabled. Remove hack when clock_gettime() is present even when
--disable-posix.
* iostream/Makefile.am, iostream/init.cc, iostream/iostream.doc,
iostream/iostream.scn, iostream/system.h:
New (C++ variant of hello).
