* | 2007-11-29 Chris Johns <chrisj@rtems.org> | Chris Johns | 2007-11-29 | 2 | -7/+9 |
| | | | | | | | * iostream/Makefile.am: Change the executable name so it does not create a file which is the same name as the standard header file. * iostream/system.h: Need to increase the number of semaphores for the libstdc++ runtime. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -1/+1 |
| | | | | | | | | | | | | * base_sp/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, nsecs/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, ticker/system.h, unlimited/Makefile.am: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis. * nsecs/init.c: Commit hack so test will compile when POSIX is disabled. Remove hack when clock_gettime() is present even when --disable-posix. | ||||
* | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | 2006-07-11 | 1 | -4/+2 |
* | Remove offending make-exe. | Eric Norum | 2005-11-15 | 1 | -1/+0 |
* | Convert to using *_PROGRAMS. | Ralf Corsepius | 2005-11-13 | 1 | -12/+10 |
* | Rework. | Ralf Corsepius | 2005-11-11 | 1 | -27/+7 |
* | Cosmetics. | Ralf Corsepius | 2005-11-11 | 1 | -3/+0 |
* | Eliminate TEST. | Ralf Corsepius | 2005-11-11 | 1 | -7/+6 |
* | Expand sample.am. | Ralf Corsepius | 2005-11-11 | 1 | -1/+20 |
* | Eliminate DOCTYPES. | Ralf Corsepius | 2005-11-10 | 1 | -2/+1 |
* | s/SAMPLE/TEST/ for improved consistency with other tests. | Ralf Corsepius | 2005-11-10 | 1 | -3/+3 |
* | Remove SRCS, PRINT_SRCS. | Ralf Corsepius | 2005-11-07 | 1 | -2/+0 |
* | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 2005-11-07 | 1 | -1/+1 |
* | Partial conversion to automake. | Ralf Corsepius | 2005-11-07 | 1 | -9/+6 |
* | 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-05-10 | 6 | -0/+133 |
* iostream/Makefile.am, iostream/init.cc, iostream/iostream.doc, iostream/iostream.scn, iostream/system.h: New (C++ variant of hello). |
