2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2004-05-10 | 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+0 | |
* iostream/Makefile.am, iostream/init.cc, iostream/iostream.doc, iostream/iostream.scn, iostream/system.h: New (C++ variant of hello). | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h, itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h, itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c, itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c, itrontask01/itrontask01.doc, itrontask01/system.h, itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c, itrontask02/itrontask02.doc, itrontask02/system.h, itrontask03/init.c, itrontask03/itrontask03.doc, itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c, itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c, itrontask04/itrontask04.doc, itrontask04/system.h, itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c, itrontime01/init.c, itrontime01/system.h: URL for license changed. | |||||
1999-11-17 | + Updated copyright information. | Jennifer Averett | 1 | -2/+1 | |
1999-11-09 | Merged tests from Task group. | Joel Sherrill | 1 | -0/+0 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. |
